Question about Frigidaire GLTF2940ES Front Load Washer
Fabric softner Everytime I put fabric softner in the dispenser it never drains during the wash and stays in the dispenser. What am I doing wrong?
  • 2 more comments
  • Anonymous Mar 15, 2014
    How do I properly put fabric softner into my Roper washing machine?
    My fabic softner flows right out of the bottom of the dispenser on my Roper washing machine what is the proper way to use this dispenser?
  • Anonymous Mar 16, 2014
    kenmore elite does not dispense fabric softner
  • Anonymous Mar 19, 2014
    Will not despense fabric softner
  • 5,911 Answers
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Posted on Oct 06, 2007
  • CJ Kirby Jun 27, 2015
    I'm having the same issue. Fabric softener not being dispensed at all. Took apart and cleaned well, still not dispensing. Could it be something else?
Where do you put fabric softner
Manually: If you're adding fabric conditioner by hand, be sure not to add it during the wash cycle. The washcycle will clean away much of the softener, so add it during the rinse cycle. Also, try to avoid direct contact with fabrics to avoid stains; instead, pour Downy into the deeper pockets of water.
How to Use Fabric Softener Without Dispenser ' Downy
where do you put fabric softener in the washing machine Google Search
Oct 30, 2017 | Washing Machines
My question is this..why doesnt my clothes smell like fabric softner?? They dont smell at i never put anything in there...and the fabric softner compartment never fully drains of its water what...
The fabric softener may be unscented.
The softener compartment is flushed during the wash cycle to clear it completely, therefore some water remains at the end.
Aug 01, 2014 | Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Fabric softner not dispensing, fabric softner remains in drawer and does not diepsne during wash cycle
Thanks for choosing FixYa and welcome. You need to make sure your hose is cleaned on the bottom of the dispenser. It is probably clogged.
Oct 01, 2011 | Washing Machines
The fabric softner will not go into the washing machine,it stays in the fabric softner dispenser during the entire wash cycle, thanks for your help
Can't help ya, as mine is doing the same thing. Not so much none of it, but there is always some left over in the f.s. compartment. I have tried adding water, but there is still some left over. It dries, and gets gummy. Every so often, I remove the drawer and clean it off.
Jan 18, 2011 | GE Energy Star WCVH6260F Front Load Washer
Maytag neptune washer is dispensing fabric softner during wash cycle! help!
not good. the board usually tells the dispenser to activate and send water to you fabric softner, ive seen two different problems on the maytags, your water valve could be bad or clogged or the board is bad.
Sep 17, 2009 | Maytag Washing Machines
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
3,155 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
