Question about Philips 25PS40S 25" TV
Tv screen is black with snow.
I have an older model magnavox television. T.V was left on for a couple of hours. The screen went black with snow. I do have cable. It was working fine when first turned on. It is hooked up to a comcast cable box. It is not doing anything, the screen is black. When i unhook the box and hook basic cable to the television it does the same thing
  • Anonymous Jan 12, 2008
    snow on screen
  • Anonymous Aug 12, 2008
    My TV was on for a couple of hours- then, the broadcast channels- 2-17, all were either black with snow, or some color and a lot of snow. I've checked the connections, but all is hooked up correctly
  • 31 Answers
SOURCE: nothing but snow
Your explanation about a different TV receiver working OK on the same aerial connections leads me to believe you have lost the tuning in the faulty receiver...
Just "snow" with no sound is a classic response for lost tuning....
It shouldnt have lost the tuning as there is a small battery(capacitor) that holds the previous receiver channel settings when you turn the TV off. But as you have had the Receiver in the back of a truck and disconnected from the power supply for some time then this is probably the culprit....
This battery (Capacitor) may be getting old and has lost its capability of sending a minute amount of current to the tuner IC (Chip) hold your previous channel settings...So if you can retune the receiver to the output from the Dish Network Receiver you should be fine again, but if the battery is shot you need a new one....or just leave the Receiver in the standby mode for a couple of days to re-charge the battery (capacitor) up.
You will need a service technician to replace this small battery (capacitor) its a special type made just for your receiver....
Hope this helps
Posted on Nov 12, 2007
  • 476 Answers
SOURCE: we can't get the dvr/cable box to work with the tv
Assuming you have connected the DVR/Cable box with a standard co-axial antenna cable, switch on the box and go to the tuning menu on the TV.
Tuning details are in the TV manual. If you don't have the manual, download here:
When tuning is completed go through the channels to find the cable box. (Note: TV will not tune to the box if it is not switched on when tuning)
If there is still no connection, the DVR/Cable box may need connecting with a composite video cable (red / white / yellow RCA connectors), rather than just a standard co-ax cable.
The connection is at the front of the TV. There is no red connector on this TV so you will have to use an adaptor to connect both left and right (red & white) audio into the white socket. Select AV on the remote control.
Posted on Mar 12, 2008
  • 55 Answers
SOURCE: screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Posted on Mar 22, 2008
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
  • 35 Answers
SOURCE: What is this tv's setup code? Needed for Comcast cable box opera
are you sure that your comcast remote requires xxxxx 5 digits for the TV code ?
10054 ?
most remotes use 4 digit codes and in my book, the philips codes are:
try these
and if you are sure that the comcast remote uses 5 digit codes then try these
make sure you get the Red LED code entered Confirmation Blink after entering the code digits.
its either a double blink or a Long Solid blink
if you have 4 digit codes it will blink before can enter the 5th, so you will know
Posted on Jun 16, 2009
IMagnavox TV stuck on VCR mode
Youre gonna need the original replacement remote , heres a link to get your replacement :
Dec 01, 2009 | Philips Magnavox 27MS343S 27" TV
I have a magnavox model 35R502-00AA help
you tv have a problem of vertical ic or cacacitor or resistor right around vertical section. that is make tv shut down in alot of magnavox tv. good luck!
Jul 27, 2009 | Televison & Video
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
I think I have the same tv. Its a philips 50 in projection tv.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try - They have instructions and kits on their site.
Jun 14, 2008 | Philips 9P5034C 50" Rear Projection...
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Screen is black
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
Magnavox tv trouble
Intermitant problems on old TV's are almost always poor solder connections. If you have done some soldering before you may be able to repair yourself, if not i wouldn't try to learn on this. Begin by gently tapping components on the circuit boards while the TV is on good chance you will tap an area and it will shut right off. make sure you are using something insulated and non-metalic. if you find a spot that is especially sensitive get to the bottom of that circuit board and begin soldering. this is probably the most likely cause but there are other possibilities. If you attempt this do be very carefull. My honest suggestion is to have a pro do it, if it just solder work it shouldnt cost that much maybe around a 100 to 150 if you can take it in somewhere.
Apr 25, 2007 | Philips 6P4851C 48 in. Rear Projection...
Philips 25PS40S 25" TV Logo
347 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
