Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Envelope Printing When printing regular #10 envelopes, the return address will not print close to the left edge of the envelope. It only prints about 1 1/2 inches toward the center of the envelope.....
  • vandyk Oct 25, 2007
    Yes we are using word and thank you
  • 36 Answers
What are you printing from? Word?
Posted on Oct 25, 2007
  • Sam Nov 01, 2007
    I think you have to go into the machine defaults and program the bypass for envelopes. A "hard"program on the machine. The print driver is not enough.
SOURCE:
Envelope orientation wrong for # 10 envelopes
It may be necessary to go back to the initial set up and make sure landscape printing has been selected. Also, envelope feed orientation could be a factor.
Dec 21, 2013 | Mysoftware My MailList & AddressBook...
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
Envelopes print crooked
A decent printer should print a #10 envelope without a problem. If this model won't do so, return it and get another printer. Suggest Epson or Canon -- AVOID HP printers.
Oct 10, 2017 | HP Laserjet CM2320nf All-In-One Color...
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Print en enveolppe with hp color laser jet 2600n
    Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
    Apr 15, 2009 | HP Color LaserJet 2600n Printer
    Envelope printing
    You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
    Thanks J
    Feb 03, 2008 | Brother HL-2040 Laser Printer
    PIXMA 830 Smudges when printing envelopes
    On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
    Another idea is to adjust the "ink drying wait time" to a higher level.
    Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Printing return address on #10 24lb regular envelope
    Are you free hand addressing or are you using "Word - envelopes and labels" tool. It should be goof free. If you are, check the pull down rollers on that end of the printer for damage or contamination. When you lift up the cover like you're installing a new cartridge, you should see the black rollers. Clean them with a q-tip and alcohol, wiping across while rolling it with your finger. If you're not using Word, pull down the tools tab and select letters and mailings, then envelopes and labels.
    Jun 29, 2007 | HP PSC 1510 All-In-One InkJet Printer
    Kyocera Mita KM-3035 All-In-One Laser Printer Logo
    325 people viewed this question
    Top Kyocera Mita Office Equipment & Supplies Experts
    Adorjani Laszlo
    AAAA262430
    Marvin
    Marvin
    Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
