Question about Instant Cameras
Spectra QPS Polaroid Camera
I need a users manual ( I am borrowing this) And do these cameras need battery changing? I can not find a place to do so on the camera Thanks Nat T
  • 5 Answers
SOURCE: polaroid onestep closeup
HI: I once owned a polaroid similar to your unit. the film comes with batteries to power the camera. Once the film is loaded the camera should be active. Good
Posted on May 29, 2007
  • 133 Answers
SOURCE: polaroid 600 instant battery change
The batteries that power the 600 format cameras are in the film pack, not in the camera. When you insert a new film pack, you're installing new batteries at the same time. hope this helped
Posted on Jul 29, 2007
  • 667 Answers
SOURCE: polaroid camera
Unless your camera is a 600SE, the batteries are in the film packs
Posted on Dec 23, 2007
  • 44 Answers
SOURCE: how to find the battery in my '' polaroid captiva slr ''
Polaroid puts the battery in the film pack, so each time you change the film you change the battery
Posted on Dec 12, 2008
  • 14 Answers
there is no battery in the camera. the battery comes from the film. the film has a battery in it already. you MUST have film in the camera for the light to go on and the flash to go off. all polaroid camera's are the same. you must have the film in the camera for it to work.
Posted on Jan 17, 2009
  • 3006 Answers
SOURCE: polaroid one 600 instant camera how to change
Change the photo pack. That's where the battery is located, you get a fresh battery with every pack.
Note that all remaining photo packs are now beyond their expiry dates as production ceased last year so many will have flat batteries or batteries with insufficient charge to last for the full ten shots. There's no fix for this: all that can be done is to rig up an external battery pack but there is no standard kit for this so it's very much a DIY project. the camera draws 4.5v and the standard battery was 6v when freshly manufactured.
Posted on Nov 14, 2009
0 characters
1 Points
Can I get user manual for Nikon MB-40 multi-power battery pack for F6 body?
I think the extent of the instructions is on the Nikon USA web site. Here it is
"The Nikon MB-40 Multi-Power Battery Pack accommodates eight AA (alkaline, lithium, or Ni-MH) batteries, or the Nikon EN-EL4 Rechargeable Li-ion Battery. The MS-40 Battery Holder comes with the MB-40. With the MB-40 attached, film can be advanced as fast as 8 fps.
When using the EN-EL4 battery, the Battery-Chamber Cover BL-3 must be used.
The MB-40 is also a vertical grip, and features a vertical grip shutter release, an AF start button, and Multi-selector and Command Dials for more comfortable and responsive shooting."
Oct 15, 2014 | Nikon Used MB-40 Multi-Power Battery Pack...
Charge indicator
Perhaps you want to charge via a USB connector on your PC. Could be the PC connections are not correct for delivering 5V on that connector.
The manual also says:
Connect the camera directly to the computer; do not use a USB hub or keyboard.
Please try to charge via the external charger that came with the camera. If that fails too, please try to replace the USB cable.
Nov 09, 2013 | Fujifilm FinePix T400 Digital Camera Black
User manual for vigorhood vl330 laminator
I'm trying to find the user manual download link for the Vigorhood VL330 laminator, as advertised on your site but you've hidden it to well - please help?
Sep 26, 2010 | Olympus Om1 Om1 Service Parts User Manuals...
Hi, I am looking for a battery for my old, 1970's, Olmpus OM-1 manual camera. Camera still works fine but battery needs replacement. Thank you, Richard Sherman
The OM-1 uses a single 1.35 volt alkaline or mercury battery (Eveready or UCAR EXP625, Mallory PX625, or equivalent). You should be able to find this battery at an electronics or an office-supply store. One online source is
Aug 21, 2010 | Olympus Om1 Om1 Service Parts User Manuals...
I have found 2 old polaroid instant cameras at my mother's house. One is a one step and the other is a spectra. They are both in mint condition--that is they look like they have never been used. Do...
No these camera do not have batteries. The battery comes within the film packet, which I might add are quite expensive these days. If you would like some places to get film just use the comment button and I'll help you with that too.
Thanks for using Fixya.
PS. Your best bet might be to consider selling them on ebay. Some collectors out there may be interested if they are in as good a condition as you say.
Feb 13, 2010 | Polaroid Image1200 Professional Instant...
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
Sep 22, 2009 | Pentax Zoom 105-R Film Camera
Could someone please tell me what battery is used for the Pentax ESPIO 738S shoot and point camera. I picked it up second hand and it has no manual or accessories. As far as i can tell it needs a lithium battery but i don't know which one or what size. Also if you know of anywhere i can get an electronic copy of the user manual that would be handy aswell.
Thanks for helping with my dilemma.
Jul 05, 2008 | Instant Cameras
User's manual
I have a Samsung Maxima 22 S and need a manual/users guide. Can anyone offer any suggestions
Thank you
Coach A
Feb 27, 2008 | Instant Cameras
Sears ks500 match meter not moving
Try cleaning the contact inside the camera and the battery cap with a hard eraser. You need good contact for power from the batteries. The inside of the cap is usually the problem.
Feb 22, 2008 | Instant Cameras
Open Questions:
Instant Cameras Logo
257 people viewed this question
Top Instant Cameras Experts
Steven Wander
Steven Wander
Are you an Instant Camera Expert? Answer questions, earn points and help others
