Maytag M3DH30B2A Dehumidifier
Problem for Maytag M3DH30B2A Dehumidifier
Drainage bypass to hose not working
By PHarstad on Oct 05, 2007
I have a de-humidifier that drains automatically to a floor drain. A month ago I shut it off for something and after I turned it back on it automatically shuts off once the water container fills. In other words, it apparently isn't draining to the floor drain anymore. I can't get inside the casing to see what's up, the hose is free of debris and well connected to the connecting point. Any suggestions?
Same Problem
Jul 08, 2008
-   i have a floor drain hooked up and the light is on and says full is there a pump or somthing that may not be working?
-   Guest
Jun 21, 2008
-   Dranage bypass is not working properly. Container fills up & humidifier turns off. Hose is not clogged & adapter is inserted properly.-   irzboss
Jun 08, 2008
-   I have the same problem. Hose looks clear and not blocked. I can't get inside the casing.-   hp12c
Best Solution
posted on Jun 22, 2008
Helpful)
irzboss
Rank: Apprentice
Rating: 85%, 1 votes
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Was this helpful?
Yes
No
Popular Solutions for Maytag M3DH30B2A Dehumidifier
Questions and Unsolved Problems for Maytag M3DH30B2A Dehumidifier
Do you recommend Maytag M3DH30B2A Dehumidifier?
Answer
Answer
dehumidifier detects moisture and comes on yet tank remains empty
Answer
Runs for awhile then it actually gets ice on the inside where the water falls into the container.... (More)
Answer
My Maytag M3SH30B2A dehumidifier runs but wont't collect water. I just got done cleaning the filter... (More)
Answer
My Maytag Dehumidifier has been constantly running. But, it now seems it is only the fan we hear and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifier Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
