Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Internal interference I have an intermittent problem that seems to show up every few months. The best way I can describe this problem with my Toshiba 51H84 TV is that it looks like I'm getting a bad reception; the picture gets waves of static interference and the audio gets a static sound, too. However, I use cable and it effects everything, even when I change the inputs and use the DVD player. It seems to be an internal interference that I can't quite figure out. It has been doing this for three days straight, which is the longest its done this for. Any ideas? Thanks for your help.
  • djgyardley Oct 09, 2007
    Thank you for replying. I don't understand what you mean by "matching transformer." Matching to what? Are you saying this is an exterior electrical problem?
  • 790 Answers
Ok you can used the matching transformer to avoid the interference. or you can buy a 'interference free'at the electronics stores!
Posted on Oct 07, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 10, 2007
    interior and exterior problem! matching transformer is for RF connector, connect to cable! this matching transformer is capable to release all signal interference!
Peavey solo series SPECIAL 112 ; Loud him , intermittently
Most of the time amplifier hum is caused by the outlet that it's plugged into, maybe no ground or there's other appliances on the same circuit causing interference? And sometimes it's as simple as a little internal feedback, certain C notes on the Guitar cause distortion with tube amps, the best fix is a $100 power conditioner like made by Monster cables or others.... hope this helps?
Feb 27, 2015 | Peavey Music
Intermittent problem starting 2002 volvo s60.
the symtoms you describe sounds like a battery fault. but if you have had the battery properley tested and is good then you either have something discharging the battery intermittantly ie. trunk light staying on or a high resistance in the main battery leads or earth connections
May 12, 2017 | 2002 Volvo S60
The audio drops out. intermittently. seems to be related to the movement of the speakers head, but not conclusive. i tested the mike by plugging into a computer. it did drop out a couple times, but again ....
Wireless audio devices are subject to interference. You are a SECONDARY user of the frequency band and hence must put up with being interfered with AND should you cause interference to a licensed service, you must cease using the system. You should try other channels on the unit to see if you can find a clear channel that will not drop out. At UHF frequencies, reflections and change of positions and surroundings can cause dropouts of a system like this. Plugging into a computer is SURE to cause problems as they emit nterference at a multitude of frequencies in operation. Best to NOT have a computer operating in the area of the receiver for this system. In the back of the manual of all of these devices and computers is a note for FCC complaince regarding interference... few read it... but you should as it is the official, legal, position about RF interference between services.
Aug 14, 2011 | Sennheiser SK 100 G3 Mic Wireless UHF
My netgear wnr1000v2 router will intermittently not send a signal that can be detacted by my laptop
This usually happens because of interference. I've found the best way to deal with it is to change the channel on the router. Stick with channel 1, 6 or 11. It always works for me. Some months I change the channel once or twice.
Dec 27, 2010 | NetGear WNR1000 Router
Low volume on Sony Trinitron
There seems to be a failure in your output drive circuit.
All electronics fail suddenly and don't show any signs until the defect is noticed except in the cases of intermittent troubles From what you have described an intermittent defect is not the culprit here. Are you using external speakers or the internal ones in the set? If you are using external speakers disconnect them and see if the internal speakers work OK. If it's both channels at the same time it's in the electronics, not in the speakers. This would require internal service. Unfortunately there is no easy fix for that. Have it diagnosed (which they can't properly do in your home unless it's a very obvious problem) get an estimate first. Those sets are very well made and reliable but nothing is perfect. You need a service call or move it to a shop.
Mar 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
BMW E39 Radio Interference on Medium wave
This is a signal strength issue.
Jun 28, 2017 | Car Audio & Video
Techwood LCD TV - picture fault
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Mar 29, 2017 | Televison & Video
I'm experiencing problems with a Panasonic DMR-EX87 DVD recorder that is less than 6mths old. In the last few months while watching programs recorded to the hard drive, the picture often breaks up in the...
My guess is that your DVD player is malfunctioning. I'd check the warranty and just try and get another. The problem you're describing sounds like the DVD hardware is probably messed up.
May 23, 2008 | Panasonic Televison & Video
Intermittent connection to wireless network
Two possibilities to consider --
There are reports the combination of a hidden SSID and WEP/WPA encryption causes intermittent connections using Windows. Recommended solution to show the SSID instead of hiding it.
Second possibility consider changing the channel the wireless communicates on in the router from the often default 6 to 1 or 11 to see if you can avoid interference on channel 6. Try the other channel if the first does not work. Interference is not only from routers but can be from in house wireless phones and other devices.
Dec 22, 2007 | IBM ThinkPad T43 Notebook
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
