If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Where is the white drain cap described here:
http://www.fixya.com/support/t3637548-f_02_mean_need...
(More)
And how can we get to it? The webpage says:
"There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean."
My Maytag Neptune won't stay running. It did not finish a wash cycle and when I try to restart it on...
(More)
My Maytag Neptune won't stay running. It did not finish a wash cycle and when I try to restart it on a new cycle, the water comes on along with the ''ON'' light for about 3 seconds and then stops. Same thing on every other setting. Light comes on then off and water stops. When I try to use spin cycle, water starts to drain and then stops. drum never moves. How do I troubleshoot this? I have read about error codes but where do I find these? My unit is a MAH3000WW Series 31 with no display. Help!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
