Question about EliteGroup 915G-M Motherboard
New ECS 915G-M Motherboard Problem
I am trying to install a new ECS 915G-M Motherboard and I cannot get the board to POST. I have tried swapping memory, clearing the CMOS, changing the battery, making sure the MoBo is not being grounded in the case, removed and re-inserted the CPU, and checked the power supply. Any suggestions on getting this to work?
    Novelist:
    Champion:
  • 231 Answers
Hi, first check if you have a red or green ready led light on somewhere on the mobo. then check if you have the cables from the front of the case attached to the correct pins on the board. your board documentation will tell you which pins and the case cables are marked as to which ones they are. regards mistyman
Posted on Oct 07, 2007
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
I have problem with my ECS A928 motherboard and I want to change it, because I can't find new one. Which other motherboard is similiar with this that I can set on my ECS iBuddie4?
Weird as it may sound, a laptop is made around it's motherboard.
Due to this, it needs to be THE motherboard that came with it.
Very seldom do laptop motherboards exchange with each other.
http://www.pchub.com/uph/laptop/64-25558-3962/ECS-A928-Main-Board-Motherboard-.html
Just a thought. Motherboard may be bad too. Hard to say exactly, unless you have it in front of you, and diagnose.
Out of curiosity what is wrong with the motherboard?
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Computers & Internet
Help (post code 21) on a 680i motherboard
Your memory isn't on the quaLIFIED vendors list but this board is trouble according to the 1000's of people requesting RMA's. ANSWER new memory or new motherboard+
Dec 13, 2009 | ECS PN2-SLI2+ (V1.0) Motherboard
Installed Intel P4 630 CPU on ECS P4M800-M7 V3.1 mobo. Cannot do POST. The mobo runs fine with Intel Celeron 326 fine.
Hello Mafatbhai, What beeps are you getting at POST?
Here is a list of BIOS beep codes.
http://www.computerhope.com/beep.htm
Well the mobo should not have any problems with the new CPU. Please ensure though that you have removed the CMOS battery to reset it. I have included a link to ECS for your specific board. Download and install all of the available updates starting with the drivers and then the BIOS updates.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jul 11, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I DONT HAVE A MOTHERBOARD DRIVER (ECS 661FX-M REV1.0B FSB800
The audio driver is a Realtek HD Audio and the lan driver should be a Realtek driver also - they can both be downloaded from links on this page.
Post your results here, especially if that link doesn't fix your problem.
Mar 24, 2009 | EliteGroup ECS 661FX-M Main Board Socket...
Mother board problem
The noise must be coming from the power supply. The only thing running before you press the power on button is the PSU.
Unplug the power cord on the PSU. Check the back of the PSU for a red slide switch. Make sure it is set for 115v. Than disconnect the main power from the motherboard. Plud in the power cord, (still hear the high pitch noise?). Swap out your power supply.
Mike
Apr 09, 2008 | ECS RS400-A (V1.0) Motherboard
ECS 915G-M Onboard audio and XP
Try to install the motherboard's driver for the sound devices...
Jan 10, 2008 | EliteGroup 915G-M Motherboard
C1 led post code
try changing your RAM with new one
Nov 08, 2007 | EliteGroup ECS P4M800-M Socket...
New board will not install com ports 1 & 2 and lpt1 printer port & floppy dr A
what you should have done was uninstalled the old motherboard drivers first as these drivers will be running the board although incorrectly, if you still have the installation disc run it as if to install, but it should show up with the option to uninstall the drivers.
Sep 26, 2007 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
915g-m5 no audio sounds
Depending on the audio chip you have, whether HD audio or not, go to the link below for the latest drivers. http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=498&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=8
Aug 09, 2007 | EliteGroup 915G-M Motherboard
EliteGroup 915G-M Motherboard Logo
629 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
