Question about Frigidaire FEB30S6D Electric Single Oven
Kitchen aid kebc278 dual ovens don't work
I've just installed a demo model twin wall ovens Kitchenaid KEBC278, the oven light is always on and the ovens don't heat. I've tried all the sabath mode stuff and checked the wiring. Is there any simple solution? I've a big dinner to cook this weekend and no tech til Tuesday.
  • jswan Oct 05, 2007
    oh yea and the close door signal is flashing
  • 447 Answers
Yes once of the door switches is broken you could jump out the switch
Posted on Oct 05, 2007
SOURCE:
My convection oven ring does not work
These tend to crack and "unzip" because they are such a tight circle... Kill the power, and meter the ring element for ohm's resistance. If the element tests ok, check the wires to the element for overheating, and if those look fine, remove the control board and look for burnt solder joints where the relays are mounted. Multimeter DM10T
Feb 22, 2015 | KitchenAid Kitchen Aid KEBS177SBL Single...
Kitchen aid torsion spring
I looked up the parts break down for this model there are 7 different ones your last 2 digits are missing this unit dos not use torsion springs the MW door should have a brown arm riveted to the door that goes into the frame this activates a switch
Feb 18, 2015 | KitchenAid Kitchen Aid 30 In. Stainless...
Needd to change kitchen aid wall oven from celsius to fahrenheit
Press and hold the Broil Max Econo button for 5 seconds.
Only this button and without turning on oven.
Feb 17, 2013 | KitchenAid Kitchen Aid KEBS177SBL Single...
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Door hinge locked up.
Discovered a faulty hinge and will replace it.
Aug 23, 2009 | Frigidaire FEB30S6D Electric Single Oven
Go to PF when there is none
wshort, As long as you are sure the circuit to the oven is not the problem,such as drop in voltage, here are a couple of suggestions. Number one is that the electronic parts for this model have a five year warranty on them and you may want to call for factory service. Sometimes the connections on the main control board become loose or corroded. Try reseating them and see if the problem stops. If not I would suspect the control board power transformer behind the control board. There are two transformers, one for lights the other for the control board. The control board transformer should have the red and blue wires while the light transformer will have the black and white. The voltage could be dropping out here. Make sure that the wires to the oven terminal block are not loose or burnt. Since you are not receiving any error codes except for PF, Im not suspecting the board itself. Catriver...post back.
Dec 26, 2006 | KitchenAid KEBC278 Electric Double Oven
Frigidaire FEB30S6D Electric Single Oven Logo
165 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Marvin
Marvin
Bruce Denton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
