Question about Hitachi GF 2000 DVD-RAM Burner
DVD Ram Disks
We have a Hitachi DVD RAM GF-2000 DVD ROM Drive. We had to repair our Windows 2000 PROF Installation and did not have installation disks for our Drive. I was able to get the drive working and it will read two of our disks, but the other three disks ask to be formatted. I felt like I needed a different driver version but cannot find the location of one to download. It may not be the driver however. What could be wrong? nikknak
  • 58 Answers
Sounds like it's just fried... Sorry... There is a universal driver for CD-rom(same with DVD-Rom drives) drives that windows uses.. so if it doesn't work it's not cause of the drivers(especially if you just reinstalled windows or it was just repaired since it reinstalls the drivers from the cd)
Posted on Jan 31, 2008
Specifications
HI, This is a MINIMUM PC specification to run your Broderbund: 1. Pentium II class processor(300 MHz or higher) 2..Microsoft Windows 98, 2000, ME, XP 3. 96 MB RAM (128 recommended) 4.100 MB free hard-disk space ( after software installation) 5. 2x or faster DVD-ROM or CD-ROM drive 6.Video Card with OpenGL driver and at least 8 MB RAM 7.Super VGA monitor (screen setting resolution at least 800x600)
But I recommend you to use Pentium IV or later for your convenience.
Nov 29, 2010 | Broderbund 3D Home Architect Deluxe 5.0...
I am trying to reinstall windows xp prof but i keep getting the blue screen and the system keeps shutting down, i have tried a different hard drive but get the same error.
unplug all devices except the hard drive and 1 cd/dvd rom drive. disable the audio device and any other unnecessary devices within the BIOS and remove all pci cards. remove all but 1 ram stick, and try using different ram sticks, one at a time, while trying to boot. if it boots, with 1 ram stick, 1 hard drive and 1 dvd/cd drive then try adding/reenabling the other devices one at a time, until you find the device that keeps it from booting.
if your pc wont load with just a hard drive, cd rom and 1 stick of ram, then it is prolly trashed. if removing/disabling one of the other devices (such as the sound card or the modem card) allows it to boot, then you have found what needs replaced.
Nov 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Upgrading HDD From 40GB To 160 GB
    1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
    2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
    3. Press C to repair the Windows XP installation by using the Recovery Console.
    4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
    5. Type the Administrator password, and then press ENTER.
    6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
    7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
      copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
    Windows goes off with the msg 'NTLDR is missing'
    NTLDR errors are usually caused by defective RAM on the motherboard. Try removing one of the RAM sticks on your board and see if computer works fine. If still gets error msg, swap the RAM stick and try again to narrow down which stick is faulty. Sometimes, its simply some corrosion on the RAM contacts which in that case, you only need to re-seat the sticks.
    Nov 05, 2008 | Umax Astra 2000U Flatbed Scanner
    Want install
    Does your computer meet the minimum systems requirments:
    Windows 98, Me, 2000, XP
    Pentium 200 MHz processor
    64 MB RAM
    160 MB hard drive space
    DVD-ROM drive
    if so, what message is it giving or how is the beheviour during installation
    Mar 14, 2008 | Computers & Internet
    Nero 7 wont work on vista
    What error comes up?
    Nero 7 is not made for vista, however I got it to work..
    General System Requirements
    • DVD-ROM drive for the installation
    • Windows® 98/98SE/ME/2000 (Service Pack 4 or higher), Windows® XP, Windows® Server™ 2003, Windows® Media Center Edition 2005,
    • Windows® Internet Explorer® 5.5 or higher
    • To install Nero 7 you must have administrative rights for all operating systems higher than Windows® 2000.
    Processor and Installed Memory
    • For writing audio and data discs: 800 MHz Intel® Pentium® III processor, AMD™ Sempron™ 2200+ or equivalent, 128 MB RAM
    • For TV recording, DVD and video authoring: 1.2 GHz Intel® Pentium® III processor or AMD™ Sempron™ 2200+, 128 MB RAM
    • For capturing and burning in real time: 1.6 GHz Intel® Pentium® 4 processor or AMD™ Sempron™ 2600+, 128 MB RAM
    Hard Drive Space
    • 1 GB hard drive space for standard installation of all components
    • Up to 9 GB free hard drive space for DVD images and temporary files
    Display Settings
    • Microsoft® DirectX® 9.0 or higher • Graphics card with at least 8 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. However, 24-bit or 32-bit are recommended.
    Optical Device
    • CD and/or DVD/DVD-RAM recorder
    Sound Devices and Speakers
    • 16-bit Windows® compatible sound devices and speakers • Installation of the latest WHQL (Microsoft® Windows® Hardware Quality Labs) certified device driver recommended
    Nero 8 was
    Nov 29, 2007 | Microsoft Windows Vista Ultimate Edition
    Hardware
    If your motherboard can take 2GB, then yes, but you need to go to www.crucial.com and run a system test and it will tell you what your board supports.
    Oct 09, 2007 | Hitachi GF 2000 DVD-RAM Burner
    Can I playback my movies on a DVD-ROM drive?
    No, DVD-RAM disc recorded on the DVD Camcorder will not play back on every drive. Some of the new DVD-ROM drives designed to be compliant with the new DVD-RAM book2 standards will playback discs recorded on the DVD Camcorder. Many previous DVD-ROM drives on the market that came out before the DVD-RAM standard was released will not play back discs recorded on the DVD Camcorder. HITACHI manufactures DVD-ROM drives for some PC manufactures as OEM products. HITACHI model GD-7500 DVD-ROM has DVD-RAM read/write compatibility.
    Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
    Hitachi GF 2000 DVD-RAM Burner Logo
    153 people viewed this question
    Top Hitachi Computers & Internet Experts
    Alun Cox
    Marvin
    Marvin
    AJMAL KHAN
    Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
