Question about Panasonic SC-HT740 System
Jammed cd drawer
I loaded 5 music cd's into my HT740 system changer, and it closed ine. However, when I went to play the first cd, it locked up and subsequentially shut down.I presume that the cd's have shifted (this happened before) and are now, in effect, "stacked", so that the drawer mechianism won't let the dawer come out. Short of taking the unit apart, how can I get the drawer open so that I can rearrange the cd's ?
The best solution is to take off the top cover. It's easy to remove with, I believe, four screws. The carousel is located right underneath the cover, so all the CD's will be exposed. However, I don't think that this will solve the problem of not happening again, since this seems to be a problem with this particular model.
Posted on Nov 14, 2007
6ya staff
SOURCE:
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
Why does my yahama cdc-505 cd changer not play cd, or change tracks
This is a result of the deck kicking out you disc as an unacceptable media. This usually means that it can not read the data on the disc or the necessary TOC (Table of Contents).
The other possibility is that your draw in detection switch has gone bad and when the processor- control type, tries to load a tray or close the drawer it is not getting the door closed signal. Depending on how the unit is programmed it might just sit there and do nothing or in your case throw the disc back out.
It is kind of telling you it wants to go see a Technician.
It could also be a bad belt that loads the Pickup assembly- it might be good enough to move the drawer in and out but the Pickup assembly needs more torque and it might not be there.
Dec 13, 2012 | Yamaha CDC-505 5-Disc CD Changer
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Panasonic SC-HT740 System Logo
105 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
