Question about Sherwood RX-4105 Receiver
Fm connection broke
The clip for fm atenna broke. Do I have to buy the whole board or can I just buy the plastic piece, unclip it from the board and replace?
  • 93 Answers
By the plastic piece, and replace it.
Posted on Oct 08, 2007
Clip for pushchair broke
Hi Kurina
We're in touch with you via e-mail about this and have a solution to your situation :)
Jul 06, 2013 | Quinny Senzz Stroller Lagoon
Hi I keep having the same problem with my land rover discovery series I, for some reason a little piece of plastic inside the door handle keeps breaking I've already replaced it once and now its broken...
I am guessing that the plastic bit is what holds the wire /rod in the hole of the lock lever It is a common connection piece in lock manufacture. If that is the case the piece that breaks is the bit that clips around the rod section(the clip fingers break off). Two fixes spring to mind is to use a piece of small wire (paper clip ) reposition the clip and tie to rod ( small zip tie may be easier) or 2 there are metal clips that do the same job( Mazda early models use these) but you could possible get them from a panel repair shop
Jun 20, 2013 | Cars & Trucks
How do i remove front grille frame from skoda octavia
I have no idea how to remove the front grille of Octavia but to solve out your problem I found out one video which is showing to replace the new front grille with old or damage one. May this video helps you. Have a look
Apr 13, 2013 | Skoda Octavia Cars & Trucks
My problem is changing the license plate bulb on a 2004 Hyundai Accent GT. They are seemingly impossible to get to. What engineering!
That's tough. You need to remove the plastic liner to get access to the connectors:
Remove all black screws off the plastic liner.
Remove small plastic cover at middle brake light using a small flat screw-driver.
Remove the yellow screw and the 3 black ones. This will relief the middle brake box.
You can unplug it (quarter-turn anti-clockwise) to ease further tasks.
Unclip the two narrow plastic covers on the side of the hatch back. Proceed bottom to top. There are 3 clipping slots. I broke the middle one on each...
Now you can unclip the big liner: there are 4 or 6 clipping slots at the bottom only. When you feel there is no more clip engaged, push the liner up. Unclipping is the toughest... Don't be affraid! There are screws if you brake one, anyway.
Enjoy the Korean engineering as I just did!
Dec 17, 2010 | 2003 Hyundai Accent
Driver's side window won't go up. Possible switch or motor? How to replace motor or get window to go up manually.
Solution: Chevy Impala Window Fix - If the window goes down but wont go up or stutters on the way up. This is a difficult process but if you have some common knowledge and a little know how it takes about an hour to fix.
I broke mine by leaving the window down and then rolling the window up while it was wet. I did this multiple times so I cannot blame Chevy for the problem. Started stuttering at 80,000 miles
Tools: Star drive screw driver, small flat head screw drivers, dental pick, Q-tips, thin sheet of hard plastic (I used two hotel room key cards) Optional: Soldering equipment
1.) Remove the two screws in the handle of the door to and take out the window control switch. (easy)
2.) Unclip the two wiring harnesses on the back of the panel - I did this with a flat head screw driver and a hotel room key card to wedge under the clips and not break the harnesses. (easy)
3.) Remove the back of the Window Switch box. Once again I used aflat head screw driver and two hotel room key cards to wedge under the clips. (complicated - most time consuming portion for me)
4.) Take off the five window switch tops, pull slighty to one side and then the other. They do come off but it feel like you're going to break the thing. (easy but do it slow)
5.) One the five button tops are removed take off the top of the switch plate. (easy)
Now you're looking at the main switch circuit board. I took a picture to make sure I knew what the circuit board should look like when reassembled.
6.) Remove the large plastic X in the middle of the board. Then use a dental pick to unclip the plastic "horseshoe" attached to the driver side window switch. (easy)
7.) Use a dental pick to carefully unclip the driverside window switch. Visually Note the position of the two "M" shaped pieces. Then take out the two little "M" shaped metal pieces. At this point the bottom right connection of the switch in my car was all blackened by lots of use. I used a Q-Tip to clean all the areas of the switch. Note: there should be some lubricant on the top of the 2 "M" shaped pieces of metal so the switch functions efficiently. (Complicated - go slow)
At this point I took apart the right rear window switch to see the difference in wear. Do not try to exchange another Switch with the driver side window switch. The driver side window switch has clips for the "horseshoe" piece that was detached earlier.
8.) Two choices to Fix the problem:
A:) Put a slight bend in the left "M" shaped piece of the switch so that the connection can be completed when pressing the window button. (Easy)
B:) Put a small dollup of solder to raise the connection area, to complete the connection. (Complicated)
I put a slight bend in the left "M" shaped piece. You can visually see the difference in the two pieces when you press them down. The Left "M" shapped piece in my Switch had to raise up an additional 1/16 of an inch to touch the lower side of the connection. With a slight bend it worked perfectly. I had my solder gun ready but figured if it went out again I could put a dollup of solder in the bottom connection to fix it the next time. No sense in taking the risk of over soldering when a simple bend did the trick.
9.) Reassemble - reattach the top of the driver side window switch ( make sure the blue dot is facing outward), reattach the "horseshoe" shaped clip to the window switch, put the large plastic X back in the middle of the Switch (it can only be put in one way, there is a gap to cover the auto roll down horseshoe piece), put the top plate of the switch back on, put the back of the switch plate back on, then reattach the window buttons to the top of the switch plate, reattach to the two wiring harnesses - Double check the button is working, then put back in the door and screw back in place. (easy)
Troubleshoot: If the button didn't work, redo steps 1-6, then slowly do step 7, then take apart another switch and compare, make sure the "M" shaped pieces are in the appropriate position, if they are add a small dollup of solder to the lower left portion of the window connection and file down the top of the solder for a flat solid connection. Reassemble and try again. If the window still won't go up. Take apart, then exhange components of another switch on the circuit board. You will no longer be able to use the Auto Roll down function but at least the window will work properly. By exchanging the pieces of another switch on the circuit board you may loose the function of that window, but you can always get out of the car and use the switch on that door to roll the window up or down.
Hopefully that works, if not, go to a junk yard and get the pieces out of another switch it can be almost any Chevy of similar year Switch.
Oct 20, 2009 | 2001 Chevrolet Impala
My heat sink clips on this plastic piece thats screwed into the mother board one of the taps broke off and the heat sink fan combo falls off the mother board and the computer over heats. what is this...
those r called as Heat sink Clip u can find in any radio shack or any HW Shop. make sure that befor u put the HeatSink put the Thermal Gel.
May 17, 2009 | HP HEAT SINK
96 dodge grand caravan drivers side power window---i have broken the nylon slides that attach to the window itself= do i have to replace the whole window monitor or can i buy the two nylon plastic slides...
It sounds like the Regulator is broken and needs to be replaced. Below is a picture of how the glass attaches to the regulator. Note the gold colored clip in the back that holds the glass to the regulator. IF the plastic piece that broke is the WHITE piece in the picture (yours may be black) then it is part of the regulator.
(the black piece in the picture is part of the glass)
480308c.jpg here is a diagram of your door glass / regulator.
b6fdf08.jpg Hope this helps
Apr 16, 2009 | Dodge Grand Caravan Cars & Trucks
How to replace a dipstick funnel on a 2003 Audi A4
There's a metal bracket that the plastic tube clips to at the top. The 2 little tabs on each side clip it to the bracket. once u unclip it, it "should" pull straight up. The one I did yesterday broke into a bunch of pieces. I had to break it off and pry the last bit off with a prybar. the new one snaps right down on.
Oct 17, 2008 | 2003 Audi A4 Cabriolet
Keyboard broken
Go to a computer surplus place. Look for a box of spare parts with key boards in it for laptops. If you look hard enough you'll find what you need and "cheap".
Sep 30, 2007 | Computers & Internet
Sherwood RX-4105 Receiver Logo
225 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
