No LNB voltage
No satellite signal
  • 1,153 Answers
What model and you can have voltage and still no signal.
Posted on Oct 05, 2007
Ikonvert TV converter box is reading lnb short what is this
'LNB' is low noise block. It is the receiver that is located in the middle of your satellite dish where the signal is collected from the dish.
You need to check the wiring at the rear of the receiver and all the way to the LNB itself.
images of LNBs
Go to Bing homepage
Jul 18, 2016 | Televison & Video
Hi I have Strong 4922A satellite that is coming up with bad or no signal not sure how to fix this.
Check for clouds and trees and and other obstructions. Once clear and your not at the limit of range of coverage check for water logged lines which can kill signal. Easiest way is to run another cable, preferably new, and by pass old wiring. Another thing it could be is the LNB. Low noise blocker. The point where the signal is focused. And I would also check you power/ signal booster. Some SWM systems need to run higher voltages and usually have a box where the wire is fed into and the box is plugged in to a wall outlet.
Jan 04, 2015 | GPS
No signal on my starview s2828+ box
Three things here the unit the cable or the LNB.
Simple things first Cable
Check the satellite plugs on Both ends are correctly fitted and there is no shorting of the core central cable and the shield. Check the cable with a meter put a loop( connect core to shield at one end) on the other end and check resistance.
2. Unit
Check your unit with a know good setup a friends perhaps.
3. LNB the unit on the arm of the dish
You should be able to get a signal from the LNB with a alignment meter. or replace with known good to test
hope that helps
Dec 06, 2013 | Televison & Video
Can't get to correct channel for satellite reception
Use the menu button on the face of the receiver. Go to settings-satellite-signal strength-view signal meter. At that point, if your readings are zero, it's one of of four things: misagligned dish, defective LNB, defective cable/fitting, defective receiver.
Aug 21, 2012 | Emerson EWF2004 20" TV
Hello, i have dream box DM 800 HD PVR
Hardware. Check the power source, the 18v is used only for the LNB.
Feb 12, 2010 | RCA DISH Network(r) 311 Satellite System
Changed from single to twin LNB, no signal
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
Nov 21, 2009 | Fortec Star Lifetime ULTRA
Satellite works fine in the day but no signal in
I have run into this problem a couple of times, once a loose connection at the LNB, other times it has been due to moisture build up (dew) in the loose connections, check all connections from the LNB through the tuner, and any other devices involved (a line map maybe?) that will most likely resolve the problem.
Sep 15, 2009 | Televison & Video
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
124 people viewed this question
