Question about Maytag Neptune MAH5500B Front Load Washer
Washer will not drain properly.
I own an older model of the maytag neptune, (one without a digital display), it works fine except the water doesn't drain completely out of the washer, the pump seems to work fine, but when the washer is off and I spin the drum, I can still hear a lot of water inside the drum. The water remaining in there is beginning to smell horrible, is there anyway I can drain the water out of the drum or possibly make the machine more efficient at draining? any help would be much appreciated. Thanks, Tucker
  • 2 more comments
  • Brent Grech Dec 21, 2007
    I have the same problem where the cycles complete, but there is a puddle of water (roughly a gallon) still inside the drum. Is there something I can run through it to unclog whatever is causing it not to drain?
  • Anonymous Mar 18, 2014
    The washer works fine until it comes to the final speed spin when it is supposed to drain all the water off the clothes but it leaves the clothes all soggy and there is quite some water in the drum.
  • Anonymous Mar 22, 2014
    leaks a lot of water
  • Anonymous Mar 31, 2014
    at the end of the cycle there is still water remaining in the drum. is there a pump filter to inspect?
  • 248 Answers
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
Posted on Oct 06, 2007
    Problem Solver:
  • 5 Answers
I Found this reply from http://www.fixya.com/users/grahamps followed it step by step and repaired mine myself. It took all of 20 Min.
I just had exactly the same problem. It turns out that the washer thought it was "continuously out of balance" because the inertial unbalance switch was not working properly. The way I fixed it was:
1. I followed the instructions to disassemble the Neptune washer found here: http://www.neptunehelp.com/index_files/Page323.htm and then in the control panel on top I found actually a very useful document stored in the control panel itself. It is called "Schematic Mini-manual LED Washer" and it contains a set of schematics for the electrical system and an explanation on how to run various diagnostics on the washer. This was incredibly helpful.
2. I checked the diagnostic code using the following procedure:
a. Plug the washer in for power.
b. Put the washer into "Service Mode" by holding the "Delicates" and "Heavy soil" keys simultaneously for 3 or more seconds. My washer showed a "00" on the screen when it was in Service Mode.
c. Pushed "Presoak" to put it in diagnostic code mode.
d. Pushed the down arrow key to read out the last diagnostic code. In my case the most recent diagnostic code was a "05", which the mini-manual says means "Continuous unbalanced circuit". In fact the mini-manual also says to "Check for: Faulty unbalance switches, Loose wire connections, Bad control board".
e. To find out how many cycles ago this happened, you can push the "Cotton/sturdy" button and it will tell you how many cycles ago this happened. I can't remember the response of my washer, but it either showed a "00" or "01".
To double check the diagnostic code, I
a. Cleared the list of diagnostic codes by holding the "Heavy soil" and "Presoak" buttons for 3 seconds while in the "Diagnostic code" mode;
b. Put the washer door back on and screwed it in without putting the entire front back on the washer.
c. Pushed the "off" button or unplug the washer and plug it back in to get it out of "Service mode".
c. Ran just the spin cycle, where it counted down to 7 and then was perfectly silent and then displayed a "00" without really trying to spin.
Double checking the diagnostic code probably wasnt' really needed, but I thought I would try it just to make sure. I did receive the "05" diagnostic code again.
3. With the washer unplugged again, I did the following to check that the switches were the problem, I checked the resistance of the circuit that has the following three switches in it: the inertial unbalance switch, the low tub displacement switch, and the upper tub displacement switch. If the circuit has effectively "0" Ohms of resistance, the switches are good. If you effectively have "infinite" resistance, then one of the switches is bad.
The mini-manual shows you where the switches are physically on the washer. The easiest way to check this is to find a connector that connects the three switches to the control panel. I found this by lifting the top panel of the washer up all of the way so I could access the top of the washer's tub. Based on the schematic from the mini-manual, the in-line connector has four wires. One side you will find a red wire with the number "23" on it and an orange wire with the number "40" on it. The other half of the connector has two blue wires connected to it, one with the number "23" on it and one with the number "40" on it. In my washer, this connector was placed on top of the washer toward the back.
To test to see if one of the switches is not working:
a. Disconnect the inline connector described above.
b. Test the resistance between the two terminals on the side of the connector having the two blue wires. I found that when I did this I had infinite resistance, so want of the switches was stuck open, indicating the "unbalanced " condition.
To find which switch was at fault, I disconnected each switch from the circuit and tested each one individually. The one that was easiest to get to was the lower tub displacement switch, which is in the front on the bottom of the washer's tub. It worked fine (0 Ohms resistance normally and infinite resistance when you push the button). The next I tried was the inertial unbalance switch, which is placed on the top, right, front of the tub just underneath the block of concrete that is mounted on the tub. For convenience, I removed the concrete block so I could easily access and remove the switch.
This was the switch with the problem (it was effectively stuck open or infinite resistance). It seems to have some rod of metal in it that moves back and forth with the washers motion, so I just shook it vigorously and you could hear the rod of metal move back and forth. This seemed to free up the switch mechanism and the switch functioned again (showed "0" ohms when it was held in about the same position as it would be on the washer). I put the switch back in place and checked the connector with the blue wires leading to all three switches as before. This time I received effectively "0" Ohms, meaning that the problem was fixed.
4. At this point, I put everything back together again (concrete block, reconnected the in-line connector to the switches, and reversed the procedure found in http://www.neptunehelp.com/index_files/Page323.htm ).
Once everything was back together again, I tested just a "spin" cycle and everything worked. You could also test this before putting things back together (probably a good idea) by temporarily putting the door on properly and trying a "spin" cycle.
Another thing to note, you could actually check the diagnostic codes and run several of the tests without taking the entire washer apart. Basically, all you need to do is get the mini-manual out of the control panel (I there are 6 screws total I took off) and run the tests before opening the rest of the washer.
In the end, it might be good to clean or lubricate the inertial unbalance switch or replace it since it will probably stick again. Unfortunately, I am not sure how it is built, so I am not sure what the best way to clean or lubricate it is. Just shaking it for the moment did the trick.
Hope this helps.
Posted on Nov 12, 2012
  • Rich Nov 12, 2012
    I Found this reply fromhttp://www.fixya.com/users/grahamps followed it step by step and repaired mine myself. It took all of 20 Min.
    1. I followed the instructions to disassemble the Neptune washer found here:http://www.neptunehelp.com/index_files/P... and then in the control panel on top I found actually a very useful document stored in the control panel itself. It is called "Schematic Mini-manual LED Washer" and it contains a set of schematics for the electrical system and an explanation on how to run various diagnostics on the washer. This was incredibly helpful.
    4. At this point, I put everything back together again (concrete block, reconnected the in-line connector to the switches, and reversed the procedure found inhttp://www.neptunehelp.com/index_files/P... ).
    Hope this helps.
Maytag Neptune doesn't drain completely
check the inlet and outlet pipes to the pump there will probably be somthing stuck in it which stops all the water from draining out
Aug 24, 2012 | Maytag Neptune Washer
Maytag front load washer model #MAH4000AWW. Just happened! Water fills then nothing. Wife says it "seems" like it wants to do something but doesn't
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Problem with the Maytag Laundry Neptune Front-Load Washer- Maytag Neptune MAH4000AWW will not drain all the water out. When the machine cycle through the drain mode it drains really well (the flow out...
Yes and no. The neptunes have always had a bad problem with that. As long as the clothes aren't soaking wet after the spin cycle you should be fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My neptune front loading washing machine does not drain out when done washing. It is an older model, can it be fixed?
Yes - likely the pump (or component of the pump) has failed - or drain is clogged. Without tearing into it - the proper fix cannot be determined.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question.
Aug 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
I Have a maytag neptune front load washer the fl light keeps flashing and the water is not draining what should i do
The dust may be deposited on filter and may not allow the water to reach the drain out valve kindly remove the dust and check it then also it is not solved check whether the drain motor is working fine or not if it is not working fine kindly replace the drain out valve
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag Neptune MAH6700AWW water won't drain into drum
Power off the wall. Drain water & check your pump for blockage. Filter as well.
Mar 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
679 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
