Question about Sewing Machines
Pfaff 1212 The machine is sluggish, has no pep. The motor's brushes are fine. Is this a rheostat defect? Some other defect? Thanks.
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
I need to know how to put the hand wheel back togther so i can try the machine. PFAFF 1212
Kary, these machines have powerful motors and they can be super dangerous if not re-assembled correctly, and more damage can result on top of that. There are lots of honest sewing machine stores with qualified personnel to take care of your sewing machine repairs safely.
Cheers,
Chance
Embroidery Services
San Diego, CA
Apr 24, 2017 | PfaFF Sewing Machines
Pfaff 1212-115- how to put the hand wheel back together. I took it apart because it Seemed to be locked. I engaged and disengaged it several times. Didn't work
Kary/Michele,
Cheers,
Chance
Embroidery Services
San Diego, CA
Nov 22, 2016 | PfaFF Sewing Machines
Hi, I have a PFAFF Hobby 420 sewing machine. Its motor is not working and there is no service centre of PFAFF in our city. Could you please guide me opening the motor??
Maybe it just needs new carbon brushes. My Bernina 830 Record resembles the Pfaff very closely. I had issues with the motor stuttering. Changed the carbon brushes and it runs like a top!
PFAFF Mail Repair Garry Machine
http://www.ebay.com/itm/Pfaff-Hobby-301-420-Serger-Overlock-Service-Repair-Manual-/171310126409
Jul 15, 2016 | PfaFF Sewing Machines
Change moter brushes pfaff 1471 model
Look on the right end of the machine for an access panel, below the hand wheel. You may also have to take the bottom off the machine. Once you are in there Look for an adjustment cam screw. completely remove that which should make your entire motor flop around. Look for other brackets and take those loose. Fish your motor out. The brushes are under a screw/cap. They are a spring and black square of graphite like stuff. Don't loose the screw or spring. While you are in there you might want to change the motor belt and or Timing Belt.
One bit of warning. If your machine has a timing belt... be prepared to have to re-time your machine.
Nov 03, 2012 | PfaFF Sewing Machines
Manual Pfaff 1212
is there thread involved in the bobbin being stuck?
Apr 05, 2012 | PfaFF Sewing Machines
The maqchine turns on, thread is fine but it will not start sewing when I press the foot petal
This happened to my machine once.....Pfaff. Machine needed new brushes..........this is a tiny part of the motor......was not expensive.
Dec 21, 2010 | Singer 7444 Mechanical Sewing Machine
Have lost the function of the foot lever
the foot lever is just a variable speed ac motor controller rheostat, they are not repairable, you just replace them.
Jan 26, 2010 | PfaFF Sewing Machines
Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Apr 26, 2008 | Sewing Machines
Sewing Machines Logo
430 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
