Question about Adobe Illustrator CS2 for PC
Errors with fonts and operation
I have installed a lot of new fonts onto the window xp and when i open illustrator after restarting the computer i received this error .. could not complete the requested operation. --- IT network administrator resinstalled adobe and now the problem still accure
    Scholar:
  • 152 Answers
That is because something is messed up and adobe is detected as a copy...
there is the trick to make it work again:
goto my pc, right click and click on manage, then go to service and applications, then click again at services, look for something that its called FLEX, right click it and go to properties, then there is this thing that its a drop down menu and click for automatic.. apply all changes and restart your pc...
i would be more specific about it but my OS version its in spanish... and translations are a bit different..
hope that helps..
Posted on Dec 11, 2007
SOURCE:
How do I enlarge my font?
Depends on the service you use. attaching two screen caps that should help you.
Gmail
Hotmail
Aug 21, 2013 | Computers & Internet
Tip
How to Install Window XP with Vista
If you wish to install Windows XP on a computer that comes with Windows Vista already installed then you will have to create a separate partition on your hard drive to install Windows XP onto. This effectively splits the hard drive into two, and keeps the different versions of Windows separate. To do this you need to open up the Computer Management screen by going to the Start menu and then right-clicking on Computer and selecting Manage.
From the Computer Management screen select Disk Management, right-click on your main hard disk where Windows Vista is installed and then select Shrink Volume. This opens up a window where you can choose how large you want the new drive partition for Windows XP to be. You need to select the size of the new partition carefully, as you will need enough space to be able to install Windows XP successfully (around 10 gigabytes) whilst leaving enough space for Windows Vista. After you have selected the appropriate amount of space click on the Shrink button to begin the process, and once that has completed you should be able to right-click on the new partition (which should be labelled “Unallocated free space”) and select New Simple Volume.
Follow the on-screen instructions to configure the partition, set a drive letter (such as E:\), give it a meaningful name such as “XP”, and then restart your computer. Whilst your computer reboots, access the BIOS and change to boot sequence to boot from your CD/DVD Drive before any other device, insert your Windows XP installation disc and then save and exit from BIOS. You will then be taken to the Windows XP installation program where you should follow the instructions until you come to the screen asking you which partition to install Windows XP to.
Make sure you select the new partition and not the one with Windows Vista installed, as this will cause problems. Once Windows XP has finished installing, you will notice that Windows XP loads up automatically, rather than giving you the choice of which operating system to use. To rectify this insert your Windows Vista installation disc and restart the computer to access the Windows Vista installation program. From the Install Now screen select Repair My Computer, and then select your Windows Vista installation and then Startup Repair. You will now be able to choose which operating system to use when your computer starts up.
on Dec 07, 2009 | Computers & Internet
Hoe to download madura font (free)
1. Download the font below... Madura Font
(when u open it it will be just a english font, dont worry about that)
2. Go to your downloads where u save the madura.ttf file, COPY it (select, Ctrl +C)
3. IMPORTANT STEPS
--Go to My Computer,
--then C drive (double click, where your operating system is),
--Double click on Windows folder (NOT Program files),
--scan through the folders and open Fonts folder, it should preview all the fonts installed on your computer.
4. Now Paste (Ctrl+V) the madura.ttf file that u copied in STEP 2. (it should say installing font when u paste it)
5. Open Madura Dictionary and it shuold work fine now.
I have tried this in Windows 8 computer so it should defineatly work fine with windows 7 and XP.
Madura Font
http://www.maduraonline.com/download/madura.ttf
Madura Software (you probably already have this installed because u only wanted the font, for other people who wants to uninstall and start from the beginning)
http://download.cnet.com/Madura-English-Sinhala-Dictionary/3000-2279_4-10571464.html
Peumal Pushpakumara
Monash University
Aug 19, 2011 | maduraonline.com Madura English-Sinhala...
I cannot install my pharaoh onto my windows vista. When I clicked the 'Install' button, nothing happened, not even an error message. please help.
Hi guys tried a lot of stuff from a lot of diff websites none worked was about to give up and found this and it worked right of the bat i dont know who the guy is but thanx a Bunch.
http://nienpaper.wordpress.com/2012/01/21/pharaoh-installation-fix-problem/
Aug 11, 2011 | Sierra Online, Inc. Pharaoh for Windows
How to install fonts in ms word 2003 with windows 7? mine is a dell laptop r series
In fact, you are not going to install the fonts in Ms word, but on your computer. If you already have the fonts saved on your computer or on a cd or on a pendrive, simply copy it/them, open control panel, and again open the "Fonts" folder and paste it/them. Now restart all the programs including the Ms word and check the fonts, the newly installed fonts will be available for you.
Most font packages have an installer with them, but since you didn't mention anything about it, I would not include it this time.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | Microsoft Computers & Internet
Error Loading Operating System
the two operating systems are not compatible. I assume that you are trying to rollback to XP on the computer. The problem is to remove the Vista o/s and install XP.
Oct 05, 2009 | Computers & Internet
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Illustrator CS2 menu problem
system fonts and adobe fonts not installed properly
Mar 09, 2009 | Adobe Illustrator CS2 for Mac
Fonts
I assume you already have fonts you want to install. If not, you'll need to buy what you want first from somewhere like fonts.com.
  1. Open "My Computer"
  2. Open "C:"
  3. Open "WINDOWS"
  4. Find the Fonts folder, but don't open it.
  5. Drag the font(s) you want to install to the fonts folder.
You might need to restart programs you have open for the new font(s) to appear in the fonts menu.
Oct 06, 2008 | Microsoft Windows 2000 Professional for PC
HINDI FONT DOWNLOAD
Go to the following webpage, and it will provide some links to click on to install the Hindi font.
http://www.hindilearner.com/hindi_font.html
Jul 13, 2008 | Microsoft Windows Vista Ultimate Edition
Adobe Illustrator CS2 for PC Logo
136 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
