Question about Sharp AL 1631 Copier
Sharp AL-1631 - would not copy.
My AL-1631 copier suddenly stopped working. When I press the copy button, nothing moves. I had checked the scanner lock and it is in unlock position. I see a red drum icon flashing in the panel. Does this mean that I need to replace the drum? The copier is about 2 years old making 30 copies/day. I do not want to spend $120 on the drum and then come to know that drum is not the issue. Can some one help me with this issue? Thanks a bunch!
  • 62 Answers
The drum will only go 1,000 copies past the drum light coming on then it will not copy.
Posted on Oct 09, 2007
  • 161 Answers
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Posted on Oct 06, 2007
2 Suggested Answers
goodgold
  • 389 Answers
SOURCE: sharp al-1631 drum sign
This simply, You it is necessary to extract the drum from device and sprinkle the scraper , toner. Afterwards tested rotate the drum for anything numbered six manual and when squeak will disappear the insert it in device.
Posted on Sep 16, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Light will not travel to the right beneath the
unlock scan by the knobe under scan unit or service scan guides
Feb 26, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 16, 2009 | Sharp AL 1631 Copier
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
Scanner problem
Try uninstalling and reinstalling the scannner. Scanner's can be tough. Try disconnecting USB cable and reconnecting too. How recently did the scanner work? Try reinstalling the scanner software/driver. Also see if you can trouble shoot by right clicking on scanner icon from control panel, scanner.
repost if none of these work. thanks.
Sep 02, 2008 | Sharp AL 1631 Copier
Problem with sharp AL-1540CS scanner
Could be hardware or software problem. Try following steps in manual ; http://www.sharpusa.com/files/cop_man_ALCSOnlineManual.pdf, if that doesn't work, try scanning from a program, i.e. adobe instead of starting scanner from machine.
hope this helps.
Sharp AL 1631 Copier Logo
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
