Question about Nakajima AE-830 Typewriter
Nakajima AE 740
Help! We can't clear the tab settings!
  • 481 Answers
Tab to the one you want to clear then press the tab clear button
Posted on Oct 06, 2007
SOURCE:
How can I do to type sign @?
The Nakajima AE-740 has a secondary set of characters on the keys in the upper right. I suspect that this alternate set is currently enabled. Do you see a Downward triangle above KBII? If so, press and hold the Code key and then press 5. Release both keys and check if the Downward triangle has disappeared from the display. Now, you should get an @ when you press Shift and then type 2.
ManualLib has the manual for the AE-740 available, http://www.manualslib.com/manual/455216/Nakajima-Ae-740.html . The information on toggling the alternate key usage is on page 43 of the manual.
I hope this helps.
Sep 01, 2014 | Nakajima AE-740 Typewriter
I need to clear tabs
tab to the set tab, push the tab clear button.
But if you are talking margins, you can only move them. Not clear them.
Feb 12, 2014 | Nakajima AE-740 Typewriter
How do I delte tabs
tab to the tab you want to remove and press the tab clear key
Jan 27, 2014 | Nakajima AE-740 Typewriter
How do you clear the tab set on a Nakajima AE-740 typewriter
Go to NADIST.COM click on current models you will finda manual there.
DickyO
Oct 24, 2011 | Nakajima AE-740 Typewriter
How do I reset the margins on a Nakajima typewriter model AE-740
If you want to set the machine back to factory settings do the following... switch the machine OFF.
While holding down the Margin Release key switch the power back ON. The machine will begin typing a pre-programmed test page....let it run for 5 seconds...switch the machine back OFF.
Give it 5 seconds and switch it back On and settings will be back to factory settings...be aware this will clear all memory of any docs or info you had in memory.
Oct 28, 2010 | Nakajima AE-740 Typewriter
Ribbon Cartridge for Nakajima AE-740 Typewriter
It takes a General Ribbon t325 we have them in stock @ 6.50.
DickyO
Cleveland Business Machines
216-241-0027
Jun 07, 2010 | Nakajima AE-740 Typewriter
AE-740 Typewriter: Nakajima AE 740 keeps typing "tc" sporadically and...
It sounds like a keyboard problem, maybe a spill, if so lit it sit on its side for a couple of days it may dry and heal itself, otherwise you will need a tech.
DickyO
May 17, 2010 | Nakajima AE-740 Typewriter
How to set tab i want to set on 75 and it remains on 60
Tab to 60 press tab clear key, space to 75 press tab set key. To clear all tabs space to rt. end hold tab clear key and press return.
DickyO
Mar 01, 2010 | Nakajima AE-740 Typewriter
Changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
May 26, 2009 | Nakajima AE-740 Typewriter
Margins will not reset
Return to the stopping point, press and release the mar. rel. key backspace to the left then press L. mar. key.
To clear tabs tab all the way yo the rt. press & hold tab clear touch ret all tabs should clear.
Hope this is helpful
DickyO
Jul 11, 2008 | Nakajima AE-740 Typewriter
Nakajima AE-830 Typewriter Logo
69 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
