Question about Konica Minolta DiMAGE Z3 Digital Camera
Won't turn on
I put my Minolta Z3 away a few weeks ago after using,then got it out today and it won't turn on. I replaced the batteries (twice) with no results. Any ideas? It wasn't dropped that I'm aware of.
Try inspecting the battery contact points in the battery enclosure. Make sure to check the points deep in the well to make sure you have no corrosion in there. Just a little moisture can cause problems.
Also determine if the place it was stored was affected by heat of cold.
These are a couple of thoughts, maybe they will help.
Posted on Nov 03, 2007
Konica minolta dimage z3 4mp digital camera firmware 1.3u can't find the software to download
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Sep 04, 2012 | Konica Minolta DiMAGE Z3 Digital Camera
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Dimage Z3 lens does not retract
Check your batteries. Are they working? Try taking them out and replacing them. If you left the camera on when you put it away and the batteries drained, you won't be able to retract the lense until fresh batteries are inserted and the camera is powered up again.
Feb 02, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Minolta za camera parts
Contact Sony they purchased Minolta a few years ago and have the remaining parts for the Dimage series cameras
Nov 05, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Focus/zoom issue with Konica Minolta Dimage Z3 digital camera w/ 12x zoom
This is a symptom commonly listed for DiMAGE cameras listed on EBay for 'parts only'. Dropping the camera I had caused the same problem and carefully 'smacking' the camera once again did solve the problem but that may have been dumb luck. Sorry but it is a service task that may cost more than the camera.
Jun 15, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Dimagez3 Battery Options
Hey bray598,
According to the manufacturer this camera comes with AA alkaline batteries so unless you bought defective batteries the ones you purchased should work fine. I would make sure the batteries are inserted properly, and make sure when you turn it on the battery cover and/or the memory card cover are closed. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
140 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
