Question about Jl Audio 300/4 Car Audio Amplifier
JL audio Low ohms indication
My speakers are making a fuzzy noise each time I turn them on. I see that a solution may be the RCA cables, but I would I check them...Could I use a multimeter.
  • 631 Answers
If the low impedance light is coming on, you may have shorted wiring or a defective speaker. Disconnect all of the speaker wires from the amp. If the light does not come on, reconnect one speaker at a time to see if you can find the one causing the problem. If the first one you connect causes the problem try a second one. If the light comes on with no speakers connected to the amplifier, the amplifier is in need of repair.
Posted on Oct 05, 2007
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
The low ohm light is amber... I have no noises coming out, when turning on the remote switch the low ohm light comes on a second before the power light comes on. I've used 8 gauge speaker and small small...
This means your subwoofer is not wired properly.
Remove the subwoofer wiring, and power on the system.
It is protecting itself from damage (if not already damaged).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Jl Audio 1000/1 Car Audio Amplifier
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
How can i make my jl audio 12w3-d6 into a 4 ohms
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Sep 12, 2009 | Jl Audio 12W3 Car Subwoofer
Jl audio 300/4 low ohms light wont go off
If the low ohms light is on then you have your speakers wired to low. I need to know some more info like what type of speakers you have running on this amp and how many. Also was it working before and then it started doing this? Check the ohms with a volt meter if you know how, if not just get a volt/ohm meter and set it to the ohms setting and then take the positive(red probe) and touch it to the positive terminal on the speaker and then the negative(black probe) to the negative terminal and see what it reads. Make sure you check how low in ohms your amp is capable of handling. If you don't know just google the model of your amp and you will find a site that has a manual or just go to JL audios web site and you should find out there with no problem. Let me know what you find so I can assist you more if need be cause I also repair amplifires for a living and have many years experienc and I'm the cheapest amp repair business you will find any where. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 15, 2009 | Jl Audio 300/4 Car Audio Amplifier
Jl audio amp 1000/1 fix
IVE HAD 2 JL 1000/1S DO THIS TO ME EACH TIME ITS TURNED OUT TO BE A SHORT IN THE RCA IMPUT BUT ALSO CHECK YOUR RCA CABLES AND THE SUB INPUT ON YOUR HEADUNIT
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
500/1- Low ohm light
Disconnect the speaker wires from the amplifier's terminal block. If the low ohm light still comes on with no speaker wires connected, the amplifier will need to be repaired.
If the light no longer comes on, check the speakers and the wiring.
Jul 15, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Sub JL 12w3 low sound
So I am assuming that you have just setup/wired this up recently? Have you had this working before?
You can have a look at the gain control on the amp & see if this have been set really low. This will help if the signal coming from your stereo is weak. The other thing I would suggest is to make sure that the amp can actually push this sub. I know what the specs say:
  • 1 channel audio amplifier
  • 1 x 350W RMS @ 1.0% THD
  • ThermalThrote full-on power assurance
  • 2 ohms stable (non-bridged mode only)
  • RCA type inputs
  • 0.3-6.0 VRMS input capability
  • Continuously variable High-Pass & Low Pass 50-250 Hz
  • Continuously variable Bass Boost settings (0 tp +12dB)
  • Frequency responce: 10-30,000 Hz
  • S/N >104 dBA at full power @ 0.1% THD
  • >80 dBA at 1W/1M
  • Remote gain control, mounting hardware & screws included
but I don't believe most of these. Many manufacturers embellish what their products can actually do! With the bigger more established brands such as JL Audio you will have no problems, their products have been tried & tested so much on the competition circuit.
Dec 15, 2007 | Jl Audio 12W3 Car Subwoofer
Low ohms light ! ! ! !
How are the speaker wired and what is the ihms for the speakers?
Dec 06, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
209 people viewed this question
Top Jl Audio Car Audio & Video Experts
matthew walsh
Level 1 Expert
Morne Olivier
Mike
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
