Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
OTC Wireless Bridge
After the Wireless Bridge installation I was able to connect my laptop directly into the hub and get to the internet. The wireless bridge was setup so that our two warehouse could stay on one network along with IP phones so that our phone system in both buildings could communicate as one. After the IP phone installation only one of the IP phone is connecting properly though they're both configured exactly the same. On the IP phone that is not connecting it reads "finding ip card". When I try to connect my laptop to the IP phone that is working correctly the phone's connection is lost until I disconnect the laptop. Should I use a crossover cable to solve this? I've been trying to figure this out for the past week and the IP phone techs don't have a resolution and the OTC tech also do not understand why it was working and now it is not. I would truly appreciate any suggestions. Thanks. Ruth Lalputan
  • 49 Answers
Care to check if the ip card software is properly installed?
Posted on Oct 25, 2007
SOURCE:
Connects and drops when using wpa will not stay connected has great signal
Please check for the wireless signal strength of the wireless router.
Try to access the internet in an area where the signal is excellent.
Oct 30, 2010 | OTC ACR201-G (00CSPP000122) 802.11b/g...
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
OTC Wireless Bridge
Alright I have good news and bad news the good news is: if you remove your IP Phones the setup will work again. Once it is working plug in one of your IP phones with Laptop plugged into the bridge. Once the IP phone is connected test if the Laptop remains connected. The use another Laptop with crossover cable to connect it to the IP Phone one question (is the IP Phone acting as a bridge between the OTC Router and the Laptop?)If it is it can pull an IP address if the OTC Router is a router and the IP phone is acting as a routed interface bridge. Once you get this to work duplicate the setup for the rest of you IP phones and laptops. BTW you do realize you are pummeling the router with RTP/UDP packets? I hope this helps Thank you, Shuttle83
Oct 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Ethernet bridge works fine with three laptops but not new HP.
you should check the wireless interface settings it might be set to work as (802.11a and the bridge is configured to work as 802.11b or 802.11 g) , usually wi-fi interface and bridges by default supports and operates in b and g
Feb 23, 2010 | HP Computers & Internet
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
How do you get wireless internet on the 366 MHZ
your processor doesnt really have anything to do with the ability to get wireless internet. You can buy a wireless card and install it into your tower. You can buy one at any computer store or even walmart. This is assuming that you have a desktop pc and not a laptop. If you have a laptop you can buy a wireless card for it also. The easiest route would be to buy a usb wireless card, as long as you have a usb port available. Here is a link to a usb adapter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130061&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Network+-+Wireless+Adapters-_-Zonet+Technologies++Inc.-_-33130061
Aug 30, 2009 | Compaq (103719-001) Pentium II, 366 MHz...
Wireless not working
Make sure the wireless pickup for the laptop, integrated or separate is installed properly and is enabled. The laptop should have a function key (check your manual) like "FN". Pressing this key and usually a function key (F1-F12) should tell you if the wireless function if built in is enabled. If the wireless pickup is USB or a PCMCIA, check the installation again and make sure the hardware is compatible with each other. It's usually not a good idea to mix vendors like using a Linksys router with a Netgear pickup.
Aug 23, 2009 | Belinea Computers & Internet
Laptop ethernet jack as a hub for another component
No. just buy a modem and a router in one that can do that kind of option without any hassle.
Dec 04, 2008 | Enterasys RoamAbout (CSISA-AX) Wireless...
How do I hookup ps3 using wireless laptop
I'm assuming here that you mean that you want to connect your ps3 to the internet through a windows laptop connected to the internet wirelessly, correct me if i'm wrong...
  1. connect an ethernet cable into your ps3 and the other end into your laptop
  2. Connect to the internet on your laptop
  3. go to control panel on the laptop
  4. go to network connections
  5. select "Local area connetion" and "wireless network connection"
  6. right click on one of them while they're selected
  7. click bridge connections
your ps3 should now act as if it was directly connected to the internet
Feb 16, 2008 | Video Game Consoles & Games
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
113 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
