Question about Kenwood KSC-WA82RC Car Subwoofer
10 pin plug wiring configuration
I would like to find the wiring schematics for the ten pin power plug
  • 1 more comment
  • Anonymous Jul 11, 2008
    do not know what wire goes were?
  • williamwoo Jul 11, 2008
    I need to know which wires are the power input and which are the speaker input.
  • rod7 Jul 15, 2008
    This is about the fifth time I've tried this web site, and I have to say it is the most useless, crappiest help site I've ever come across ! Absolutely useless.
  • 7 Answers
10 pin plug wiring configuration - 7e83231.jpgI had the same problem.  Here is the picture I used.
Posted on Jul 21, 2008
I need 2 know where can i buy the power/speaker input forKenwood KSC-WA82RC Car Subwoofer
Posted on Jan 03, 2009
Necesito el digrama
Posted on May 03, 2008
SOURCE:
Tip
TOSHIBA BIOS PASSWORD REMOVAL DONGLE
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration. But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port. Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :- 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
on Feb 18, 2010 | Computers & Internet
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
Can't get the password from bios
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
May 06, 2010 | Toshiba Satellite A135-S2276 Notebook
How to remove the cmos or bios password and want to remove the password in booting up, my laptop is toshiba satellite a135-s4527
Mar 18, 2010 | Toshiba Satellite A135-S4527 Notebook
How to reset the boot password in toshiba portege a100 laptop
Mar 08, 2010 | Toshiba Portege S100-S1133 Notebook
Toshiba satellite pro l 350 bios password reset
This is the ONLY other way, save paying Toshiba and filling in proof of ownership forms.
Feb 20, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
I want to replace the navigation unit in my 2002 camry with one from a 2007 camry. Most of the plugs on the back of the units are identical -- except for the black plug. The 2002 unit is a Fujitsu Ten...
You are not going to be able to perform this replacement scenario. Due to the fact that you are dealing with 2 different manufacturers, the wiring is different. There is no cable that is available to give you what you want.
Actually, there is a second component in the NAV system, that is what the unique cable plugs into. If you want to switch the NAVs , you need both components, and the correct wiring harness.
Hopefully, I have saved you a considerable amount of time and effort. Thanks for considering FIxYa fo advice.
Oct 28, 2009 | 2002 Toyota Camry
1996 Dodge Ram Factory Trailer Wiring Schematic
all you need is a cheap continuity tester, any one to help tap on the brakes..7pin is just like the 4 pin w/extra power wire for acc.lites,electric brakes.when you buy the 7pin rec.,comes w/wiring schematic standard to all trailer rec.- you can do it..kev-mn.
Dec 10, 2008 | 1995 Dodge Dakota
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Kenwood KSC-WA82RC Car Subwoofer Logo
2,059 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
