SOURCE: setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
SOURCE: Timex Expedition alarm beep
good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
SOURCE: can't turn off the alarm on a timex Expedition Watch
buy a Casio wrist watch at KMart for around $17.00. They last five years, then the
band breaks and you buy a new watch. I timed the traffic signal system of our city for 20 years from a Casio wrist watch. Now in retirement, I have a Time Expedition which has several alarms which I do not need, and can't turn off. We change the time twice annually, so having alarms and chimes go off without warning ca bve a nuisance.I found some instructions on a website which shows how to turn the alarms off.
SOURCE: need to turn off timex
There are two ways to find the user manual for your Timex watch.
If you are still unable to locate your user manual, you may email Timex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
