Well, later today, i tried it again, to see maybe if it was the battiers. Now the camera does turn on, and the lens comes out half way, and then shuts off.Well, later today, i tried it again, to see maybe if it was the battiers. Now the camera does turn on, and the lens comes out half way, and then shuts off.
When I turn on the camera, the lens comes out then immediately goes back in and shuts off. I have tried several sets of new batteries, but it continues to do the same thing. I can't recall it being dropped. It worked fine just a few days before.When I turn on the camera, the lens comes out then immediately goes back in and shuts off. I have tried several sets of new batteries, but it continues to do the same thing. I can't recall it being dropped. It worked fine just a few days before.
i have the same problem when i turn it on the lens come out about 1cm out in goes back in and turns back of it says on when i put it on the Favortes and press review to get the picture off it but can't take pictures have not work since we went to Queensland from TEMORA NSW but we did not drop it we took 3 pictures of a baby turned the camera off turned back on to show someone and did not work tryed new batties still did not work my cousin had a camera and when the queensland and her camra was a kodak z150 and did not work after taking a picture of the baby at the same place were we went from temora too and had the same problem so we thought the baby was causse buyed a new one a Pentax and took picture of the baby again but it did not brake. Funny holaday.....i have the same problem when i turn it on the lens come out about 1cm out in goes back in and turns back of it says on when i put it on the Favortes and press review to get the picture off it but can't take pictures have not work since we went to Queensland from TEMORA NSW but we did not drop it we took 3 pictures of a baby turned the camera off turned back on to show someone and did not work tryed new batties still did not work my cousin had a camera and when the queensland and her camra was a kodak z150 and did not work after taking a picture of the baby at the same place were we went from temora too and had the same problem so we thought the baby was causse buyed a new one a Pentax and took picture of the baby again but it did not brake. Funny holaday.....
You can't post conmments that contain an email address.
What has happened now is 'I think' The Zoom mechanism is wrecked. switching on again cause a 'strain' or overload and something else burned out.
The reapair bill you will like even less - cut your losses and buy the next cameraWhat has happened now is 'I think'
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
If you've dropped the camera you may have damaged the lens housing - which will require professional repair, but the problem you describe is frequently due to
corroded battery contacts inside the camera. Remove the batteries and
wipe the camera contacts firmly with a clean cloth (heavy corrosion may
require cleaning with a fine wire brush, steel wool, or fine
sandpaper). Remove any residue that may have fallen into the battery
compartment during cleaning, clean the contacts at both ends of the
batteries, and reinsert them in the camera. This cleaning cures the
problem about 90% of the time, and I hope it works for you.
Probably the lens is not the right circumstance and needed repair from you. Check your lens, if you are able to disassemble and assemble back your digital camera. If you can't, take it to the service center.
The only way to fix a lens error is to send it into repairs. Call them at 800-706-2534 option 2 and they will tell you the closest place to send it to.
Hello, I'm Mark Faith from the states. I purchased the CASIO EX-Z700 series. However, I accidentally dropped the camera when the camera was on and the lens was extended. It makes a grating sound, and the monitor screen said "Lens error".
Now, the camera is turned off with its lens extended. When I see the lens from the top, the lens position is more concentrated to the right, and the gaps between each lens is bigger on the left hand side of the lens.
I sincerely hope this would help you to analyze the lens situation. I'll be patiently waiting for a list of solutions. Thanks.
