Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
OTC Wireless Bridge
The OTC Wireless Bridge was setup to use IP phones and have our computers plug into the phones to access our network and the internet. When the wireless bridge was first installed I was able to plug right in and get access; I was able to ping and IP address, go to the internet etc. Once the IP phones were installed I am unable to get any connections on my laptop via the bridge. There were two IP phones installed, however, only one of the phone is working although both phones are configured exactly the same. When I try to plug my laptop into the IP phone that is working correctly it loses it's connection. The one IP phone that is not working is reading "finding IP card". Do you have any suggestions on what else I might try. Do I need to use a crossover cable when I connect the laptop to the IP phones to make it work? Thank you for your assistance. Ruth Lalputan
    Genius:
  • 1,139 Answers
Alright I have good news and bad news the good news is: if you remove your IP Phones the setup will work again. Once it is working plug in one of your IP phones with Laptop plugged into the bridge. Once the IP phone is connected test if the Laptop remains connected. The use another Laptop with crossover cable to connect it to the IP Phone one question (is the IP Phone acting as a bridge between the OTC Router and the Laptop?)If it is it can pull an IP address if the OTC Router is a router and the IP phone is acting as a routed interface bridge. Once you get this to work duplicate the setup for the rest of you IP phones and laptops. BTW you do realize you are pummeling the router with RTP/UDP packets? I hope this helps Thank you, Shuttle83
Posted on Oct 09, 2007
How do I find out what the ip address of the bridge so that i can access the setup page?
wire the bridge into the ethernet port on your router. access the setup page of your router and check the DHCP client table. you should see the name of the bridge there with the corresponding MAC address. Just type the ip of the bridge into the address bar of your internet browser, you should be able to access the setup page of the bridge by then.
Sep 17, 2010 | Linksys WET610N WirelessN Bridge...
Trying to run the setup cd for the wet610N on a WGR614v7 router and getting error 107 after it tries to find the device.
setting this up would be easy if you do it manualy. Just wire the bridge into your router, access the setup page of your router, go to the DHCP client table and take note of the ip address of the bridge.
Open you internet browser then type the ip address of the bridge into your address bar.
You'll be asked for a UN
Sep 15, 2010 | Cisco Linksys WET610N WirelessN Bridge...
How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
OTC Wireless Bridge
Care to check if the ip card software is properly installed?
Oct 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Cannot Connect Gaming Console or Remote Computer to the Internet
1. Make sure the gaming or remote computer has a correct IP address with the same IP subset address as the wireless router or access point. 2. Turn the bridge off. 3. Turn the bridge on. 4. Recheck the IP address for the gaming computer or remote computer. 5. Turn off all network devices. 6. Power on the wireless router or access point. 7. Wait 30 seconds. 8. Power on the bridge. 9. Check to ensure the bridge connects to the wireless router or access point. 10. Power on the gaming console or remote computer.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
133 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
