Dishwashers Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The control panel works intermittently.
The dishwasher has an electronic touchpad control. Usually when you try to start it by touching the touchpad to select the cycle you want (Pots and Pans, Normal, etc.), nothing lights up on the control panel. If you keep trying, once in a while it will select a cycle. Then when you push the start position on the touchpad it may or may not start. If it does start, then it seems to go through the cyce that you have selected and wash the dishes. Do you know if this might be a faulty electronic control panel or the switch membrane (touchpad)?
Anonymous
Level 3:
Genius:
  • Master 1,239 Answers
  • Posted on May 03, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1239
Questions
8
Helped
407250
Points
3279
HI friend
it may be also timer problem .....did you touched it with wet hand...better to check timer,,,
thank u,,,,,,,,,
My Haier 18 dishwashers control panel does not illuminate.
First, confirm that the dishwasher display is working. If the display is still working, try pressing some of the touchpad buttons. If some of the buttons respond correctly but others don't, it is likely that the touchpad is at fault. (Some manufacturers sell the touchpad separately from the control panel. Other manufacturers require that you purchase the touchpad and control panel together. If you cannot replace the touchpad individually, replace the touchpad and control panel.)
Belling dishwasher wont start all the lights are on
Check your owner's manual and make sure the child lock settings are turned off. Reset the dishwasher -If your dishwasher won't start but the lights are on, there could be an issue with the start button.
If the dishwasher is working but you get no response when you press the control buttons the reason for that is probably either a faulty touchpad, faulty control panel or a main control board.
Touchpad and Control Panel: If some buttons work and other don't it is likely that the entire piece needs to be replaced. It depends on your dishwashers make and model if the touchpad and control panel are sold as one unit or separately.
Good luck
Source: https://www.electrafixbc.ca/appliances/dishwasher.html
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 • Dishwashers
Regency problems
Touchpad
Main Control Board
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 • Dishwashers
2helpful
I have a Kenmore elite 13102 dishwasher touchpad that has begun to crack around the start button. Does this necessitate changing out the whole electronic control pad or is there a part that is the...
You will need to replace the touch pad assembly. You can purchase the part from the link below.
Kenmore elite Dishwasher Parts Link
You can read an article that explains how to make this repair yourself at the link below.
Appliance & Refrigerator Repair
Mar 22, 2011 • Dishwashers
2answers
F1 is popping up on my digital display and a beeping noise comes along with it. What does that mean and how do I get it to stop?
Your F1 error is
: indicating an electronic control malfunction
: (a $250 part) or a control panel (a $60
: part)? Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control panel (without the electronic control) but on some models the keypad linked below can be used to repair the one on the original control panel.
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
