Having a problem with a "paper jam" on my Canon MP830. Printer says there is a paper jam in the out slot. no such paper is there. we have taken apart the printer the best we can and we can not find this myserious paper. Can someone please help?
Comments:
Oct 09, 2007
- Nevermind we found the paper. It was a small 4x6 that was stuck in the back
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP830 All-In-One
text is not consistently dark, first two lines are, then this alternates with two lines lighter, two...
(More)
text is not consistently dark, first two lines are, then this alternates with two lines lighter, two lines darker. I have cleaned the print heads and the test printing (not text) shows up fine, and no nozzle problems
