Question about Optimus STAV-3770 Receiver
Optimus Stav-3770-Turns on then off
I turn my reciever on then it says "powering off" right away everytime i turn it off. I hope you can help. thanks
  • 4 more comments
  • steelrazor Mar 01, 2008
    My STAV-3770 does the same thing. You turn it on then several seconds later the display says powering off and it shutsdown.
  • Anonymous Nov 29, 2008
    my stav 3780 receiver keeps powering off. It gives the message powering off and then turns itself off.
  • Anonymous Jan 25, 2009
    I have this problem too, any solutions??
  • quest22 Feb 13, 2009
    I have the same problem. they told me it was the fuse I need to change. Need a solution.
  • carolc_84 Apr 05, 2009
    I have the same problem I'm bummed...but I've had the receiver (Stav 3770) for almost 9 years if i'm correct...what kind of fuse does it need...i hate to have to buy a new recevier is it worth changing the fuse...??? It out of nowhere shut itself off...sometimes it would do that if like the volume was way too loud...so my speakers wont blow...but usually it'll turn right back on...When i turn it on...the light flashes then says "powering off" and turns off....Has anyone figured out what to do??? Thanks!
  • Anonymous Apr 13, 2009
    SAME PROBLEM ! MY STAV-3770 RECEIVER DISPLAYS "POWEROFF" A FEW SECONDS AFTER TURNING IT ON, THEN SHUTS ITSELF OFF. I WOULD LIKE TO KNOW WHAT CIRCUITS THE PROTECTION SYSTEM MONITORS. HELP ----
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: how to hook up TV so it can be heard on Optimus STAV 3770 system
how to hook up on my hd tv
Posted on Oct 28, 2008
Anonymous
  • 118 Answers
SOURCE: Can I connect a stav 3770 optimus to a directv dvr
sure...red and white out of the dvr into any input on the 3770 and it should work if its setup and working properly. good luck
Posted on Feb 11, 2010
adamncc1701
adam dombrosky
  • 158 Answers
SOURCE: When I turn my optimus
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
Posted on Sep 07, 2010
gmoney311
SOURCE: i need a new remote
Buy a universal remote, program it manually and try the Yamaha codes first.
Posted on Sep 29, 2010
Mi receptor optimus cuando enciende aparece power off y se apaga en pocos segundos
tengo un problema con mi stav-3770 y cuando lo enciendo me dice power off que debo hacer en ese caso ??
Jan 08, 2013 | Optimus STAV-3770 Receiver
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
How do I set up the surround sounds to my T.V. using the optimus 3770 audio reciever?
Does your TV HAVE surround sound? THAT would be different.
Some simple text intructions for thge receiver...
http://support.radioshack.com/support_audio/47464.htm
Feb 04, 2011 | Optimus STAV-3770 Receiver
When I turn on the STAV-3770, after the five seconds for the inital click that is ready to go, the unit turns off and back on and keeps repeating this process.
Most of these units come with a replaceable fuse in the back (about the diameter of a penny). I believe that the unit will shut itself off if the fuse is blown. Excessive use, moisture or a power surge will blow the fuse. Radio shack may have a replacement for you to buy. I would try this first, as it is a fairly inexpensive solution. If it turns out that you have a more serious electrical problem with the unit, I would consider replacing it. The new 5.1 systems are cheaper than ever, more energy efficient and sound better to boot.
Sep 26, 2010 | Optimus STAV-3770 Receiver
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
Sep 07, 2010 | Optimus STAV-3770 Receiver
I need a new remote to replace the old one for a optimus stav 3770
Sep 06, 2010 | Optimus STAV-3770 Receiver
Security light
There is a great write-up about this here: http://newrockies.com/vatsbypass. This was the only way I was able to save my Park Avenue.
Mar 26, 2010 | Megatronix - PASSLOCK-SL2 - GM Passlock...
TURNS ON AND POWER TURNS OFF RIGHT AWAY.
Is the battery fully charged? If so unplug the device before turning it on. My roomates HP will shut off if plugged in while powered on it is most likely due to the compound on the heatsink.
Feb 13, 2010 | HP Compaq Presario V6000T Notebook
Optimus STAV-3770 Receiver Logo
466 people viewed this question
Top Optimus Audio Players & Recorders Experts
Ekse
Larry Stiles
Larry Stiles
Marvin
Marvin
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
