Question about Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator
Refrigerator Jenn Air, freezer at bottom. ice keeps building up in freezer, then it doesn't get cold up top.
  • Anonymous Dec 18, 2007
    refrig supplier installed something on ea side of the freezer drawer and this has cured our frost problem
  • Donna118 Jun 16, 2008
    The freezer air vents keep frosting over and fridg is warm !! Only 3yrs old...help
  • 473 Answers
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Posted on Oct 05, 2007
SOURCE:
I have a Jenn-Air side by side refrigerator. It has built up ice in the very bottom about three inches thick. What could be the problem?
ice is water freezing so check where the water is getting in ( leaking water bottles being frozen, bad door seals, too frequent door opening etc
Jul 10, 2016 | Jenn-Air Refrigerators
Water not draining to pan when defrosts draining into freezer causing ice build up at bottom of freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Jenn-Air JSD2789GES Side by Side...
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
I have a Jenn-Air JCD2389G Side by Side Refrigerator. The bottom of the freezer keeps things frozen, though the top of freezer & refrigerator remain mild to warm. There is not an excessive amount of...
It sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Apr 25, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Frost build up Jenn-Air JFC2089HTW
have you tried to re align the hinges? is the hinges broke?
Jun 25, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Jenn-Air Refrigerator Not Cooling
As others have noted, the solution is counter-intuitive but easy. The refrigerator keeps cold on this model by cold air coming over from the freezer side. So most likely it is ice blocking the freezer coils or the fan that moves the air. So turn off the freezer and defrost it. You will need to remove the big white plate on the back of the freezer (on the inside) to most effectively get the ice to melt. You can use a hair dryer for this, or just leave the freezer sitting with the door open for several hours.
Jul 09, 2008 | Jenn-Air JCD2389G Side by Side...
Open Questions:
Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator Logo
417 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
