Question about Alpine CDA-7998 CD Player
Help for Repair...
Hi, my cd player dosnt work because i crashed driving, the problem is that the player its on but it dosnt open.... it trys but after trying it turns off.... i live in venezuela and i dont know where i have to take the cd player or how to repair it....
Does it have a disk stuck in it? If so you need to take it out then remove the disk then replace it and try again. Other than that any Alpine dealer should be able to give you assistance in where to take/send this for repair. Good luck.
Posted on Oct 05, 2007
After unrepairable problems with the CD-Drive of an Yamaha CDR-HD1000, I got a CDR-HD1500 on guaranty. During burning of the 11th CD, it crashes (Check Disc) with 7 fresh Disc's of several...
Try different burning software to see how that works. Get the free Ashampoo suite that is easy to use, fast, and costs nothing. But if you continue to have issues, that replacement burner is no good.
Sep 13, 2017 | Yamaha Audio Players & Recorders
No system disk has been found, insert CD and press any key to continue. There is a black screen on my PC, no matter what CD I put in, or pressing any key, the message above just appear again on the...
this problem come from your har drive
your hard drive not recognized by motherboard
to solve, open your computer, disconnect hard drive cable then connect again
then turn on your computer
this problem usually found on computer with sata hard drive
Mar 31, 2011 | Computers & Internet
My dri8ve will not open and close with the push of the button.
Hi. if you are using a cd rom that dosnt open and close. try the following. unplug your HDD cable to the hard drive. just use cd rom. if cd rom open. you must use a separate cable. if problem continues then you must take cd rom to the nearest Computer electrical expert to fix.
good luck
Nov 11, 2010 | Computers & Internet
Disc draw does not close fully. The draw closes but the armature that holds the disc does not engage. Is is possible the drive belt is slipping and not allowing to engage the armature?? Advise please...
Hi:
This is ususally a indication that the unit is either out of timing, or like you suspect a worn drive belt, most modern DVD players use gears, but it could very well be belt driven, seems the clamper is closed when the tray trys to go in.
Nov 09, 2010 | Sony CDP-C910 10-Disc CD Changer
Cd rom drive problem
Hi, you can purchase cleaning CDs for your CDrom, if this does not work it probably meens your laser has gone and you will need to buy another one
Jul 04, 2010 | HP (176135-630) (176135630) Internal 48x...
My Sony CFD SO1 keeps skipping/display light keeps flashing
That is an electronic problem. Probably a just-about-to-break cable in the motor of the CD drive, that sometimes causes a short and turns off the unit, or sometimes makes it to comport erratically and produce the buzzy sound. If you have electronics knowledge, then you may open and check the wiring harnesses. If don't, take it to your local electronics repair.
Nov 20, 2009 | Sony Boom Box With CD Player & Cassette...
CD player continuously trys to eject and drains
You need to take your car to an auto electrician to fix the issue. It is most likely due to an i/c glitch in the CD system. If it is damaged, you might need to replace it.
Kind Regards,
Oct 19, 2009 | 2003 Pontiac Grand Am
Windows media player let me burn cd but other software dosnt work
All you need to do is change the device it is going to burn the files to. Apparently it is currently set to burn an .nrg image file to your hard disk. If you click on the down arrow next to the Image Drive, you will see your DVD/CD drives listed there.
Jun 07, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
WINDOWS XP WON'T LOAD TO HARD DRIVE
1) If you are trying to install from a bootable disk and trying to make a fresh install, you will not come across this error.
2) If you are trying to repair the existing installation, you might need to use FIXBOOT command and try. Please refer the below link before you try this.
http://support.microsoft.com/kb/314058
Apr 21, 2009 | Computers & Internet
Alpine CDA-7998 CD Player Logo
75 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
