Question about KitchenAid KSRS25IL Side by Side Refrigerator
Ice Marker Problem
I put a new unit in a older refrigerator, Amana, the water valve works, the refrig is at -8 degrees, I have power. my supplier gave me a second new unit to try. same problem no motor movement. Leveled unit checked my wiring. What else could it be?
  • 447 Answers
How are you checking power TO the icemaker???
Posted on Oct 05, 2007
  • 473 Answers
On most Amana models the light switch for the freezer is in the same circuit as the ice maker. Check to see if your light turns on and off by pressing the switch. Now the ice maker will only cycle when the bimetal in the ice maker is cold enough. You can start it thru a cycle by jumping the the bimetal with a wire. You do that by inserting each end of the wire in to two small holes on the bottom right hand side of the module. Will need to remove the white plastic cover on the icemaker to get to it. Hold the light switch closed and it should cycle if it has power and the switch is ok. When you let off of the switch the cycle will stop. Be sure to remove the wire about 10 sec. after the cycle has started. Then watch for water fill. If no water fill then there is another problem. Let me know how this turns out and we can take other steps if necessary.
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge ice marker no 120v to seloniod water valve
It sounds like the plug-in for the solenoid valve is not making contact with the terminals on the solenoid . You can either buy a new connector or cut the plug for the solenoid and crimp 1/4 inch sta-cons (insulated type) to the wires.
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Amana ARB224RCW ice maker
Aug 16, 2009 | Amana ARB224RCW Bottom Freezer...
No ice
You need to test the dual water control valve on rear of refrigerator with and ohm meter. Disconnect both sides from the power connections at the control valves. Test each coil with an ohm meter. You should get the same or close to the same reading on both coils. Let me know what your model number is and I will be able to tell you the part numbers, Thanks, Sea Breeze
Jul 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
63 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
