Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave resets when started
Just started this morning .. GE Spacemaker Microwave with outside ventilation simply resets similar to power cycle after 2 seconds of running .. have tried several times, configuring clock/date each time .. all other functions seem to work (surface light, etc.) except heating .. moved to different circuit, same results .. any ideas?
  • bobterp Oct 05, 2007
    both, it definitely power cycles after 2 seconds of cooking, then the display is garbled and comes back with the "GE -- We bring good things to life" and "Please Press Clock" .. its been in service for 1.5 years and i have a service contract on it, so i've called it in .. can you please elaborate on the interference that may cause the "scrambled brains", because that seems to be my symptom .. hopefully i'll be able to sound a little more intelligent when the service tech arrives !! .. thanks ..
  • GE Master
  • 9,173 Answers
Could you explain what you mean by "resets similar to power cycle after 2 seconds of running"? Do the characters on the display get garbled, or is it like someone just unplugged the oven and plugged it back in? GE had a rash of "underperforming" magnetrons on several models. They would sometimes end up with stirrer damage, bad diodes, waveguide damage, and/or interference which "scrambles the brains" of the unit and makes them reset like they had been unplugged. The usual fix is to replace the magnetron, stirrer and high-voltage diode as a kit, and they used to cover this, but may not any more. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. In that case, the oven would have to be replaced. To get the details and see if yours is affected, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Even if your exact unit is not on the list, you may have this problem. You can contact GE Customer Relations at 1-800-386-1215 and tell them your problem and they will put you in touch with a local authorized servicer. Feel free to post back if you need more info. I appreciate your thoughtful rating of my answer.
Posted on Oct 05, 2007
SOURCE:
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Condensation in door glass of GE XL1800 microwave
Your ventilation seals may be aging, but they have nothing to do with microwave energy leakage, (And microwave energy is not ionizing radiation anyway, so it does not cause cellular mutation or cancer)
You should check your grease filters (if you are venting to the outside) or your charcoal filter (if recirculating).
If you are venting outside, check your outside vent flap for proper operation, and check your outlet and ductwork for a bird's nest or mouse nest, etc.
If you have other questions, feel free to contact me directly, because FixYa doesn't always notify us when there are follow-ups.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 09, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave was working fine but just stopped this morning. Is there a way that I can replace the high voltage fuse? Is it located in the panel inside the microwave?
You have not mentioned the make and model. Any way you can check the AC fuse on the power board inside the oven. If it is blown off you can replace it by a similar one, around 10amps fuse.
May 16, 2009 | GE Profile Spacemaker Over-the-Range...
Replacement model for jvm152h
Please clarify which model Spacemaker Micro you have .. and Spacemaker microwave ovens can be configured to vent inside or out simply by repositioning the blower assembly prior to mounting it to the wall bracket so turn it on and determine where the vent air is being distributed ( outside or inside) ..
Oct 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
113 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
