Question about Toastmaster T75R Classic Cool Steel 2-Slice Toaster
Old Toastmaster toaster - MOD 1B5
Hi, The knob that you push down (which usually hitches down and slides up little by little as the toast is toasting (you can still hear the ticking noise when it's suppose to be sliding up), doesn't hitch down, but instead slides right back up. I removed the bottom steel plate and cleaned it out. I thought there was something blocking the bottom of the track so that the knob wouldn't go all the way down, but still the knob won't stay down to slide up slowly with the toasting. Can you help? While this is an old toaster, it is much more durable, heavy than what you can buy today. Many thanks.
oscarn
  • 110 Answers
SOURCE: Toastmaster toaster
thermostat seems to have given way, needs replacement
Posted on Sep 26, 2007
Falling Down
  • 67 Answers
SOURCE: Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Posted on Nov 30, 2007
Ian Prins
  • 11 Answers
SOURCE: Repair manual for T2020WT
Hey annaway, all toasters are repairable, but that only determines what the problem is, If you google teh type of toaster, under the following
1. www.google.ca
2. type repair manual
3. toasters
4. look for your brand name
Posted on Dec 06, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
  • 71 Answers
SOURCE: My toaster is hung up on '2'...and flashes. I just want a peice of toast!
Certainly seems like it's last day has gone!!
It did give you good reliable service didn't it !!!
Posted on Jun 04, 2008
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
My toaster will not pop up but continues to toast
The best thing you can do is call the manufacturer. It sounds as if it has a default.
Sep 18, 2014 | Toastmaster TP424 208/240 - Pop Up Toaster...
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
Wont pop up old toastmaster toaster
Hi mon42,
The 'click' sound indicates that the pop up mechanism is most likely intact. The problem of not popping up is most certainly caused by a worn or broken or disconnected spring which forces the toast to pop up once it's done.
You will need to take the toaster apart and look for the mechanism which pops the toaster up (look for the mechanism attached to the tray in which the toast lies). There should be a spring, or remnants of a spring, which should be fairly easily replaceable with a similar spring. This should be readily available from your local appliance spares store.
Please let me know if I can help any further or furnish you with more details. As your toaster is very old, it will be too difficult to find any documentation on the specific model.
Best wishes,
Graeme.
Jan 06, 2012 | Toastmaster Kitchen Appliances - Others
We cannot locate our manual that came with the toaster.
you dont need one, put bread in, push down lever, if toast is too dark, turn knob counter clockwise a little bit
Oct 29, 2010 | Dualit 25375 2-Slice Toaster
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
Retro Westinghouse toaster works but toast will not pop out
YES .westinghouse used a clock timer to time all of there toasters in the 40s and 50s . remove the push down knob (there is a set screw under it) and the 4 screws under the toaster . the top will come off inside next to the push down lever there is a little clock timer . a drop of oil on the moveing parts of the timer will get it ticking again .....test your work by pushing down the lever stem (with it unpluged ) it should pop up when it times out . puting back on the top can be a pain but it does go back but at some point you may wonder ! with all toasters put down a towel before working on one to keep from scraching the mirror finish ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Feb 21, 2009 | Kitchen Appliances - Others
Nov 26, 2007 | Toastmaster TP409 4-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Toastmaster T75R Classic Cool Steel 2-Slice Toaster Logo
189 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ellenskitche
Steve Allison
Steve Allison
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
