Question about iLO 3200 32 in. LCD Television
42in ilo lcd tv
Picture flashes and scrambles up like running vertical is on turbo, the screen then goes blue green red and white. i shut it off for ten minutes and it is okay for about an hour. howdo i get walmart to fix. only had it since june 07.
Depending which cables you are using, you should check your cables to see if you have them in the right order. The other issue with some ILO's they run really hot.  Keep the TV away from the wall and allow air flow.  If necessary, you may want to buy computer fans and mount them on top of the vents with air flowing outbound. (Using Coarse Thread Drywall Screws to mount-top two holes only) You will need to buy a universal adapter set to 12V. It will take some rigging with wires. (Red for  positive and black for ground) Test the fans before mounting. The fans run independently. Also, you will need a switch to turn off the fans when TV is not in use.  The problem with some models of ILO's , there are not enough vents for the heat build up.  Where ever it's hottest on the back panel, place the exhaust fan there. On bigger screens you may want 2-3 exhaust fans.  It is a $25-30.00 investment but your TV will last a lot longer...years
Walmart will not be able to help on this problem.
Posted on Oct 13, 2007
How do I fix Samsung ue40h5030ak led tv that the screen is flashing red green blue white
LCD panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 26, 2016 | Samsung Televison & Video
Ilo 42" Wide Screen LCD TV...Picture Malfunction
From some of the forum threads I've read about this, it seems like there were early issues due to bad firmware, but they have all be resolved with the recent updates. It also appears to be very easy to replace the hard drive. Just swap it out, format from the menu and you are done.
u will neeed to get it updated
Jan 25, 2008 | iLO 3200 32 in. LCD Television
Screen goes green with white vertical lines
I think either your red and blue filaments are not fully intact causing the green to take over or you have other electronics like subwoofers too close to your tv.
Try degaussing your tv, it might have a degaus button at the back or check the menu.
If you've tried those things without luck, respond with more details.
Hope that helped.
Jan 01, 2008 | Zenith C32V37 32" TV
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Lines distorting the picture appearing on the screen
It's the Electrolyte Capacitor ( Elco )on the Vertical board that already damaged, try replace it with new ones.
Oct 18, 2009 | Dell W3000 30 in. HD-Ready LCD Television
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
iLO 3200 32 in. LCD Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
