Question about Electronics - Others
USB Storage When I plug the USB "thumb drive" into my USB port, and look for it in Explorer, it's not there. Used to work, but not now. What's up?
  • 11 more comments
  • ong1234 Dec 02, 2007
    While using pendrive (Imation 512K, 1 year + old) - connected to laptop, suddenly cannot save / read files. Indicator light is also not on. Try many other computers - cannot access.
    Is the data lost? How to retrieve data?
    Ong
  • shal maha Mar 11, 2008
    i bought a pendrive 4 gb i can not see it on my laptop but i connect to my friends laptop i can see it on explorer. i tried to get its drivers but failed to do so ?
  • colby36 Apr 14, 2008
    My flash drive worked last night, but it no longer works--will I be able to retrieve the items off of it or is it completely lost--if so, how do I get the things off??
  • Anonymous Apr 22, 2008
    I plug my converter drive in but cant find it
  • raswy Aug 29, 2008
    I have problem with my removable disk when i connect it,my hardtop ask me to iinsert a device and i used it last night.How could i retrieve it?Help me please
  • R0xxyx3 Sep 15, 2008
    sandisk memorystick pro-duo 1G is no longer recognized by camera, printer, or CVS printer stations. I have all pictures from trip to CA And Australia on there. Was told that if I mixed video on the card along with pictures this may have screwed up the format of the card. Is this true & how can I get ny pictures off this disk now? Is there a place I can send it or go to? Am very disappointed about this situation, please help me!
  • Anonymous Nov 13, 2008
  • Anonymous Nov 21, 2008
    i have maxell 2gb flash drive.when i insert in computer and want to open teh flash drive the massage appear "please insert a disk into the drive d".how could it be solved?
  • Anonymous Nov 29, 2008
    i need driver of sandisk
  • ilcoor Jan 03, 2009
    The indicator light flashes twice on my internal digital media slot, but it is not recognized on my computer.
  • rainayoung22 Feb 06, 2009
    My card used to work but now my computer won't even recognize that i put it in. I've tried hooking my camera to my cumputer like i did last time when it worked and i've put the card directly into to computer and it still doesn't show up. I need my pictures on my computer. Help?
  • Anonymous Mar 28, 2009
    I have a TDK Trans-It. It appears on the menu for My Computer, but when I click on it, I get a message to "Please insert a disk into drive F:". Once it found it but not all the media, and when that happend it also found it twice but could not open the second one. It allows me to stop it for safe removal...sometimes. I've had to reformat it once already, and I've been using it for about three weeks. I've tried every combination of removing it and putting it in other ports, rebooting, etc.
  • Anonymous Mar 24, 2014
    I've tried to update my mp3 thumb drive and it says its updated but still won't play music
    Problem Solver:
  • 8 Answers
Is there an indicator light on the drive? If so, is it on?
Posted on Oct 05, 2007
Hello my friend. If the USB is mounted on location 0 and it does not appear in the disk manager even you setting the option show hidden then you got a ROOTKIT problem. Download the Sophos anti-rootkit and remove it, reboot your PC and its done.
Posted on Oct 15, 2009
2 Suggested Answers
SOURCE:
SOURCE: Thumbdrive not working
I received no response from you, so I contacted another organization. They have communicated with me letting me know they are working the problem. I have no inclination to either ask for your assistance or refer you to others in the future.
Posted on Sep 11, 2008
I bought a brand new fantom drive externl hard drive used it once and now it wont show up when i plug it into a usb port
Try to plug the external hard drive to a different port. if its not working try to use other usb device like ipod, or thumb drive and if the other usb device works it means the problem is the external hard drive it self. If the problem still the same the problem is the usb ports probably the motherbaord
Sep 03, 2011 | Fantom Computers & Internet
I bought a used car and it already had a kenwood kdc-x890 installed. my question is when i plug my zune or even just a mp3 player into the usb port it responds with [n/a data].
The KDC-X890 will play MP3s that are stored on a USB mass storage device, such as a USB thumb drive. It won't play music from another MP3 player such as a Zune through the USB port, but you could plug your MP3 player into the auxiliary jack.
Mar 04, 2011 | Kenwood KDC-X890 CD Player
Usb drive use
Most thumb drives are used like floppy or rewritable optical discs (excluding ReadyBoost and the bootable versions). They are most often formatted as FAT drives (under Windows). If the drive is good and the USB port is good, plugging the drive into the computer's port should trigger a "new hardware found" message from Windows.
In Windows, open My Computer or Computer (depending on the OS) and you will see it listed under Drives with Removable Storage. You can use the file explorer to navigate through your regular drive and copy files to the thumb drive or the reverse. (I usually open two different windows and drag the files with a right-click then select Copy.) Synch programs can let you keep the thumb drive and hard disc copy at the same version. Alternatively, you can save a file directly from the program that you are usng to edit the material. (File > Save As and chose the destination). You can also open the file from the thumb drive in a similar mode. To avoid lost data, always select the Safely Remove Hardware from the taskbar (or Eject from the File Explorer) before unplugging the drive from the port.
The biggest problem is that the FAT formatting limits the number of files you can put on the disc unless you keep them in folders. (The same number of folders can be in the home directory as files without using folders.)
Bootable thumb drives (as well as those that can run software directly from the USB drive) come with software that lets them do this. Then they act like any optical disc with Autorun and executable programs. Readyboost is dealt with completely by the OS and keeps the drive (or portion of the drive) separate from the area that will store files.
Sometimes these drives do fail. Getting the data off the flash memory takes a professional most of the time.
I hope this helps.
(You can copy all of the files from the thumb drive and reformat it at intervals. Then copy files back if you are concerned about file fragmentation.)
Jul 24, 2010 | Verbatim VER95327 USB Hard Drive
Remote storage drive won't (USB) network to laptop
In fact the USB port on the DIR 825 is meant for share port.
So if you plug in a pen drive it should work.
May be the storage drive which you plugged into the router is not plug n play or something like this.
Mar 15, 2010 | Computers & Internet
Is there any way to transfer the info on 1 usb to another
Yes, if your computer has two or more usb ports available. Plug each individual usb thumb drive into its own usb port. Open up explorer and verify which usb drive has the information on it and then copy all of the information (select all & copy) now drag and drop to the other usb port that contains the thumb drive you want to put the info onto. Each usb port will identify itself with a seperate drive letter.
You can also cut and paste instead of drag and drop.
Feb 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
JumpDrive FireFly (4gb) not showing up in windows explorer or disk management
do you hear the USB hardware installation tones from windows when you plug in the the drive? If so then you are know the USB port is working. If you do not..try other USB ports. If you hear the noise...Right click on My Computer and click on Manage. Click on Storage and then Disk Management...see if you are having a conflict of drive mappings (i.e. F:/ or E:/)..you can relable the drive letters by right clicking on the drive in the right pane and selecting Change Drive Letter.
Jul 11, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Sep 10, 2008 | Electronics - Others
Usb ports do not active
One of the great features of USB devices is they can get power from the USB port. Plug in a thumb drive and it just works. The power for operating the thumb drive comes from the USB port. This works for small devices like a thumb drive but not something big like a scanner. The scanner need its own power supply.
There could be several explinations for what you are seeing. Could be you are plugging in a device which is sucking too much power and the laptop is shutting it down. I would test the port with something small like a thumb drive and see if it works. If the thumb drive works but the other device does not a couple of things could be going on. Maybe the device just need power - is there a way to plug in a power supply? Or maybe the device is broken and shorted out. Does the device work on another computer?
If something like a thumb drive does not work then it is a problem with the motherboard. Could be the USB ports are bad. It happens and there usually is no easy fix short or replacing the motherboard ($$$). Occasionally there is a BIOS setting for the USB ports. A bit of a long shot but worth a look.
A possible work around would be to get a power USB hub. A hub plugs into a USB port and provides 4 or 7 USB ports. Good ones come with a power supply. When the hub is plugged into the power supply it does not draw power from the computer. Might solve your problem.
Aug 23, 2008 | Acer Computers & Internet
Electronics - Others Logo
581 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
