Question about Samsung SCH-a870 Cellular Phone
Phone not charging
My phone charger stopped working yesterday. I tripped over the cord while it was charging and somewhat forcibly yanked the phone charger out of the phone to answer a call. Afterwards, the phone charger did not work in the phone. I thought the phone charger was not working, but I brought a new charger today. The new charger does not work either! Could there be something wrong with the valve on the phone itself? What should I do? Is it even worth fixing?
  • 1 more comment
  • Anonymous May 28, 2008
    where i plug my charger in doent work
  • Anonymous Sep 06, 2008
    my samsung zv40 doesent wanna charge with a normal charger and only some times it charges through the usb cable please tell me how to fix it my self and what i need to fix it [email protected]
  • LisaTe Dec 18, 2008
    My phone went dead.So I hooked it up to the charger.But then the light didn't come on to let me know it's charging.So I moved my phone around a little.I held it up in the air and sort of pulled it away from the charger in the wall to see if the light would come on cause it seemed like a shortage in the charger.And the light did come on at one point when I was moving my phone around.But then I accidently moved and I tried moving it around again but it didn't work.I can't go a day without using my cell.So can anyone help me out?
    Sergeant:
    Champion:
  • 221 Answers
Take it to the Service Center. The Internal Charging Port has malfunctioned.
Sahaja Yoga is the ONLY SOLUTION to all the Problems of World.
Posted on Mar 31, 2008
Phone reads searching svc, I take battery out and put back in and dial *228 then it reads unsuccessful connection. can you help me?
Posted on Jan 26, 2008
    Sergeant:
  • 452 Answers
If the new charger is also not working then surely it's the problem of that charger port (valve). It must have been damaged.U need to get it fixed from the hardware vendor.
Posted on Oct 22, 2007
SOURCE:
My phone was working place it on charger went back and the phone is dead will not come on
The same thing happened to me. It's probably your charger porter. did you somewhat yank the charger out sometime or did it fall of a table or something and the charger yanked itself out when it fell (if it fell). If that's the problem, try putting the charger in the phone & hold the charger up, worked for me. You could also try a different charger or buy a battery charger like I did. There's the link if of the battery charger if needed. I hope this helps!
http://onepluswireless.com/products/universal-external-cell-phone-battery-charger-charges-most-brand-phone-batteries
Dec 03, 2015 | Blu Studio 5.0 Mobile Phone
Why did my phone chargers stop working?
Probably yanked on the cord too hard or violently.
Aug 18, 2014 | 2003 Honda Accord
My zte score wont charge unless i press the charger into the port and hold it there forcibly
Please try using a different charger and battery to check if the is with the device or with the accessories. If the same issue persists even with different charger or a battery, then it might be the issue with the charging port of the device.
Dec 30, 2012 | ZTE Score
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
My blackberry phone wont power up or charge
It probably wont power up because it wont charge. the USB port may be bad preventing it from charging. I assume you have tried both the wall charger and the computer connection and have not had any luck with either one. Its probably the USB port has stopped working. common problem if the USB cable had been yanked or severely stressed while plugged in to the phone
Feb 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
Unablt to plug the charger cord into phone
See if its ddamaged from where you charge the phone. you might be able to bend it back into place....
Aug 14, 2009 | Motorola Mobility RAZR V3
LG Venus Charging Problems
try borrowing another charger that fits your phone, If it works change the charger as the cord might be broken//
Oct 03, 2017 | LG Venus VX8800 Cellular Phone
Charging phone in Europe
Yes!!
Any adapter that accepts up to 220volts will work with just the plug end adapter. However if it only accepts 110 you will need to purchase a voltage converter.
Have a safe trip in europe!
Check out my blog at:
http://www.pchelpforanyone.blogspot.com
May 11, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Samsung SCH-a870 Cellular Phone Logo
769 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
