Replacing a DVD DRive in Averatec 5110
How do you remove the old Drive. I have taken all the screws out but there seems to be something keeping the keyboard attached. Any suggestions.
  • cor69vet Oct 05, 2007
    Thank you for your help. It is a laptop not a PC. I did figure it out. The keyboard was pasted on not screwed on so I had to pulled then the DVD screw was accessable. Thanks again.
    Problem Solver:
  • 18 Answers
If your removing your dvd drive, disconnect any usb and power cables, hold down the power button for a few secs. You should be able to undo the screws and cables and then slide it out of the holder. Some times there are screws hidden. Usually there are four. If it catches on the front 'plate', you may have to remove it, but be careful, sometimes there are wires attached. This is, of course, for a desktop NOT a laptop. Dont worry about disconnecting your keyboard, but make sure that anything that has its own power is disconnected. This also depends on the design of your case as well. Good luck.
Posted on Oct 05, 2007
SOURCE:
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Dvd drive is broken and does not work can it be fixed rest of computer work fine thank you
yes it can be fixed... you should be able to order a replacement DVD drive from the manufacturer.
Mar 12, 2011 | Averatec 3360-EH1 Notebook
How to replace the dvd drive in a toshiba Satellite A45-S250
Most toshibas have a small screw on the bottom of the computer, next to the memory cover. take screw out and the use a paper clip or turn on laptop, to eject dvd drive, then turn off laptop, unplug power, then pull on drive outward, shold slid out of laptop,.
if replacing with new drive remove metal screw clip off the back of old dvd drive and screw onto new dvd drive, slide in and replace screw!
Jan 13, 2010 | Toshiba Satellite A45-S250 Notebook
Keeps restarting
There's seems to a problem with your laptop, obviously. This behaviour is a bit natural when a computer suddenly found an error it will keep in rebooting to try to free itself of error. Why not have it check again.
It could be the newly installed dvdrom is not properly reset in bios configuration. Have the new drive be redetect. And set it also in OS, change the settings to the newly installed drive. Or maybe uninstalling and reinstalling its driver to fit into the new drive.
hope I help.
Apr 21, 2009 | Averatec Computers & Internet
Gateway M305CRV PC Notebook Won't Boot
Remove system battery and power cord.
Remove the keyboard screws, flip KB toward front. Then you will see a small battery, remove the battery for about 30 seconds then replace.
After battery and KB replaced power on unit.
Aug 29, 2008 | Gateway M305CRV Notebook
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
Averetec 3200 dvd replace
If you are asking, how to manually eject a disc from a drive, I can help.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
Feb 15, 2008 | Averatec SDW-042 DVD RW Burner
Changing HHD on Averatec 5500
Hi Sunergos!
Replacing the drive is real easy! Diconnect the power and remove the battery. On the bottom of the laptop, lower right hand side, you will a panel, with one screw. Remove the screw, and lift the panel. The drive had a plastic pull tab on it. Lift up gently, and pull to the right. Don't lift too high. The drive will come right out. The Drive is held in a "tray" with four little screws. Remove those, and place the new drive in the same way. Just reverse the procedure, to install it, making sure the pins line up the with the female connector. Hint - wait 10 min or so before putting the drive in, or it won't recognize it. Newegg has a 120 gig drive for that lappy for $74. Upgrading my Averatec 5500, I ended up with a 3400+ CPU, 1 gig ram, and a 120 gig harddrive, that dual boots to Vista or XP, and is just as fast in either OS. Good Luck!
Dec 03, 2007 | Computers & Internet
Replacing DVD/RW-R drive on HP ze2000
very simple, just remove the casing then disconnect the wires from power supply colored yellow,black,red (connector) to dvd rom, then disconnect the cable ribbon to dvd rom unscrew the dvd to the casing then slide out the dvd rom backward( if you are facing the cpu) bfore you install the replacement, you need to check your dvd rom which you have taken out and compare the jumper orientation to your new dvd rom. if the old one is in cable select or in primary or in slave just follow the old one. now if you are finish checking the jumper orientation, you may proceed in installing your dvd rom on casing, install back the screw on bothe sides and all the connectors. power on thats it your finish just proceed to the my computer and check if this appears in it or in the device manager. i hope that this helps you, any questions or clarifications feel free to ask me.
Nov 22, 2007 | Computers & Internet
Buying a hard drive for the Averatec 3200 Series
I have a tip. Don't forget to set up the drive as master or slave (depending on what you want the drive for). I personally have forgotten to double check this on numerous occasions (its always the simplest thing you overlook with everything) only relizing when I have the case screwed back on and am trying to boot the drive up.
Aug 11, 2007 | Averatec 3200 Notebook
Open Questions:
Computers & Internet Logo
166 people viewed this question
Ekse
Alun Cox
