Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother MFC-5540cn Print Head replacement
How difficult is it to do and is it possible to purchase a printer head retail?
  • 832 Answers
Its quite siple to do if you are able to use a srewdriver... 1#: Go get a 2.hand dcp 110c or 115c at eBay with a good printhead (and a broken scanner glass???). It should print without probs! opening mfc 5440 is nearly the same as a mfc 215c, since all brother printers are of the same built :) follow pictures here http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c For your mfc you have to unfasten some more screws which can be seen very well. After that you can take up the cover. Now you should realize that it looks the same inside as on photos given in the link. Read the rest of "how to change the printhead" here: http://www.fixya.com/support/t209702-get_color_print_black_works_fine there is just one more difference to your mfc! You have to take out the sensor in the ink cart assy of your mfc 5440cn which is clipped at the side and reinsert it into the cart assy of the "new" one! This sensor is placed at the BK cart and signals the mfc that there is a HBK cart. Thats it. This job could be done for a novice within less than an hour. If there are questions afterwards or during surgery post it here!
Posted on Oct 05, 2007
SOURCE:
I got this almost new printer from my dad,i got the ink for it today and now i am testing it out ..first it said it was cleaning now its printing but there is nothing coming out on the paper
If the machine hasn't been used for a long time, then I suspect the ink in the print head and/or the supply tubes to the head has dried out.
Try running the print quality test/cleaning sequence a few times to see if it clears - press the ink management button on the machine and follow instructs.
If after several cleans it still isnt printing, you'll have to try more agressive cleaning techniques. Search for "brother print head cleaning" on YouTube for ideas.
Jul 11, 2014 | Brother MFC 420CN All-In-One InkJet...
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
Brother printer (model MFC-J265W) not printing black - how do I fix?
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 14, 2012 | Brother MFC-290C Multifunction Color...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
It says machine error 41 on my brother MFC 5100C machine
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Jan 10, 2010 | Brother MFC 5100c InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc 210c printer
Difficult solution !
http://www.fixya.com/support/t258155-remove_print_head
Jan 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
1,769 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
