Question about Toshiba D-R2 DVD Recorder
Remote problem I am having trouble switching my remote back to dr1 I cannot access the menu on my screen.I have tried the channel buttons on the recorder itself and after hit setup and 1 but no results
  • mbchiz Dec 13, 2007
    i have a toshiba d-r2su and i got into the menu and switched from DR-1 to DR-2 and now my Remote will not work ,Please help how do i get back to DR-1
  • Anonymous Mar 11, 2008
    I tried the solution that you suggest but it won't work what other solution do you have for me. please reply
Flip open the door on the remote and press setup and 1 at the same time . this will switch it back to DR-1
Posted on Jan 08, 2008
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
Bought it used without a manual. when turned on the channel is set to a channel that we dont receive. cant figure out how to set a new start channel.
You can access the on-screen menu by pressing the Vol+ and Vol- buttons together on the front of the TV . Alternatively use a remote and press Menu to access the menu (not all low end remotes will match the feature) An exact replacement remote is available here: . Then use the channel up and down buttons on the TV to select menu items. If using the remote use the play, fast forward, fast rewind back and pause to go through the menus. Press Menu to go back one level in the menus.
Once you have the menu up, go to the bottom of the list to Install. Select Tuner Mode (the options are Antenna, Cable and Auto) and make sure that is set correctly. Next select Auto Program to look for all available channels or Edit Channels to change the channels you will see when you change the channel with the Channel up and down buttons.
Please note that the TV only has an NTSC (analog) tuner and must be used with a set-top box to see any channels other than the remaining low power stations that have not switched to digital.
Once you have a new channel list, the TV will remember the last state it was in. (Please note that the A/V inputs are reached by pressing Channel up or down past the tuner channels.
For more support information: see .
I hope this helps.
Oct 23, 2010 | Philips Magnavox MS3252S 32" TV
Any way to access on-screen menu on Sharp 13F-M50 without remote
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
Aug 08, 2009 | Sharp 13VT-K100 13 in. Combo
Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
3rq8 (Triarcuate)
Jul 25, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Can't find button on tv to change source in order to play dvd
I'm assuming that you do not have access to the remote for the TV. If you do, you can simply press "INPUT" on the remote.
If you have no remote, try this:
Press the "MENU" button on the TV.
Press "CH Down" until "Channel" is highlighted, and "MENU" to select it.
Press "CH Down" to highlight "List and Labels", and "MENU" to select it.
Press "CH Down" to go below channel 1, you should see "FRNT" displayed.
Press "MENU" to get out of the Menu system.
You should now be seeing whatever is plugged into your front connectors.
Simply pressing one of the channel buttons will switch back to normal TV mode. I could find no faster way to access the front connectors without using the remote.
Feb 11, 2009 | RCA F25442 25" TV
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
No remote specific to Sharp combo to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Can't change channels!!!!
take the batteries out of the check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Toshiba D-R2 DVD Recorder Logo
265 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
