Question about Dryers
Dryer Stopped My dryer just stopped working. It won't come on at all. Not sure if it is the motor or what. We've had not indication except that we have noticed that we often had to dry loads twice as it was not drying completely on one cycle. What should I do???
  • BZYMOM Oct 15, 2007
    Thanks to all those who responded regarding my Roper dryer. I decided to buy a new one----however, upon delievery the cord on the old one was longer than the new one. When the delivery man decided to remove the old cord...he found the wire burnt!!!  I refused the new one. We bought a new cord for $16.00 and replace it. The dryer works...however, I am concerned that I still don't know why the cord burned and will the new one be exposed to the same situation. Anyone have any insight..??
Just encountered same problem and discovered burned cord leading to red terminal. Replaced cord and now dryer works. There was significantly burned plastic where cord connection took place. The melted plastic makes me nervous. Hope this will not repeat. Thanks to Byzmom and Amigaman.
Posted on Jan 10, 2008
  • 248 Answers
Probably has a blown hi-limit fuse. Long dry times are often caused by restricted vent. Clean vent often. When vent is restricted it causes heat to build up in dryer and this blows hi-limit fuse. It's protecting your dryer from a possible fire. Location is dependent on model and gas or electric.
Posted on Oct 06, 2007
  • Gerald Griffin
    Gerald Griffin Oct 15, 2007
      We see this happen from time to time.  The connectors are crimped on the ends of the cord.  Sometimes these crimps loosen up causing the connection to heat up and eventually burn off.  You might want to check the area where the cord connects to dryer.
      UNPLUG CORD FIRST!!
      Take cover off and inspect for other burned wires.  Also make sure connections are all tight.  Chances are the problem was solved by the cord replacement.
Put a load of laudry in the dryer that was still holding water. Dryer stopped running and there was water sitting in the dryer. Now the dryer won't run
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch.
To save time and back and forth dialog, I`ll mention the most likely based on your description, "put a load of laundry in the dryer that was still holding water. Dryer stopped running and there was water sitting in the dryer. Now the dryer won't run"...and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason... likely from the excessive weight of the load you put in.
It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
If you`ve already taken the back of the dryer off to gain access you should have no problem. If you never have, it`ll take some time.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
i.e.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 29, 2012 | Bosch Nexxt 500 Dryer
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
My dryer (model# YE20HN3 won't turn on, stopped working.
heatman101
Jul 24, 2011 | Dryers
Our dryer just won't turn on. We noticed that it was throwing cool air out rather than hot heat. A couple days later went to use it and it just stopped. We checked to see if it was our wall mount...
First make sure there is 120 Volt between either outer terminal and the middle terminal, and you need 240 Volt between both outer terminals. Then unplug the dryer and check the wiring. If you see burnt wire ends that could be the problem. The first place to check is where the supply cord connects inside the dryer. The next most likely places would be at the timer and switches. If you hear a humming sound when you are turning the dryer on, that indicates a motor that froze due to dry bearings. Are you sure you have a good belt? Some dyers have a switch near the motor that turns everything off when the belt is broke.
May 08, 2011 | Whirlpool Inglis IP8200 Dryer
Dryer stopped heating, still tumbles, also the push to start switch has to be held down now for it to work at all. checked voltage (good) checked cotinuity of all parts and all were good except the...
heatman101
Feb 09, 2011 | Kenmore 63942 Dryer
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
My electric GE dryer stopped working today, when
sounds like the motor is running, the belt could likely be broken and be the culprit, this is if the motor is turning for sure after you start the dryer
Sep 30, 2009 | GE Dryers
Dryer stopped working
Yes it maybe a fuse problem .But first you want to make sure the door switch is working.
May 21, 2008 | Dryers
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
137 people viewed this question
Top Dryers Experts
