Question about HP Pavilion zd8000 Notebook
Vertical thin linings on lcd monitor
Sir, i hav 3 vertical thin lines on my laptop lcd it was one before one month plz help me
    Scholar:
  • 151 Answers
It is due to immense use of your laptop. So dont worry, off it for some time and on it again. It will not come. It is the same problem i m facing with my laptop. All the best.
Posted on Oct 05, 2007
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Laptop monitor have vertical lines apearing out of nowhere...
LCD needs to be replaced.
Common problem called "Tab separation".
Jan 10, 2009 | Toshiba 14" LCD Monitor
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Thin blue line
What have they told you to do? This will help us in troubleshooting. Is this still under warranty?
Aug 20, 2007 | HP f2105 21" LCD Monitor
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
HP Pavilion zd8000 Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
