Question about Frigidaire ATF6000ES Front Load Washer
Frigidiare washer not doing anything
I plugged my washer in for the first time and when i go to start a load it starts filling with water for a second and then stops. after a min or so it will start filling again and then stop after a few seconds. it does this a couple time and then doesnt do anything. ive pulled codes and have gotten e43 and e5e different times. the codes tell me to replace the control board but doesnt say which one. anyone have an idea as to what i can try to find out what i should replace?
  • slawless77 Oct 11, 2008
    I have not gotten the E43 error, but have the same symptoms and gotten the E5F (communication problem) error. We have checked all the wiring between the motor control board and the control board. It doesn't actually seem to be overheating, there is no burning smell, the motor and belt seem fine. The washer has sat unplugged for days, then will start with this exact same problem when we go to plug it in and start it up again. We have had the washer (Kenmore 417.44052400, made by frigidaire I believe) approx 3 years or so. Thanks!
  • Anonymous Mar 22, 2014
    when we start the washer it starts to fill and then stops
    New Friend:
  • 4 Answers
Washer stopped working, similar to your experience, water would start and stop after a few seconds and not progress. It displayed E5E error when prompted for code. I opened up the back of the machine and noticed that a connector was not connected to the control board, i removed the control board to get a better view of where it belonged, and slid the connector over the same control board, closed up the machine and it's back in business. Repair men told me that I needed to replace the control board, but I didn't need to, it simply had disconnected.
Posted on Jul 23, 2015
    Problem Solver:
  • 15 Answers
Before replacing check the voltage to the machine. Make sure the machine is not on any extension cord.when the machine is turned on make sure the voltage doesn't drop more than a few volts.
Posted on Oct 10, 2007
What to do about FH error on Whirlpool Duet washer?
unplug the washer to clear the board.turn on the water after one min. plug back in and try again
Sep 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
1) please the timer for defective, however clean the contacts very well, loose wires, or broken and repair.
see the diagram attached
2)no cold water, see this and fix it.
God bless you
Jul 02, 2012 | Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Sep 20, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Dryer works - washer won't do anything!
Sounds like an Electronic problem.
You should call service.
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Try :
A&E Factory Service
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Aug 18, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer does not fill with water
, did you try changing water temps switch to different settings, hot cold amd warm alll no good?? do you even hear a slight humm when trying to fill???, how about trying to put into spin cycle, does it do anything??? if you listen closly (put your ear to the timer knob assy)can oyu hear anything??? if not its quite oossible that you have a power issue, check your incoming power for 110 volts.
Mar 25, 2008 | Kenmore 24032\24036 Top Load Washer
Washer stalls while filling, must press start button to get it going again
How is the water tempture is it hot water when you have it set on hot?? and vice versa?? you may have a clogged fill valve screen you will need to shut off the water and remove the fill hoses and check the screens that are in the water inlet valve use a opened paperclip to hook and puul them out to cleans Hope this helps If not plz let me know and we can go futher into the mach
Jan 24, 2008 | GE Profile Prodigy WPSE4200A
Frigidaire ATF6000ES Front Load Washer Logo
424 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
