Question about Sharp AR-BC260 Color Copier
Shart AR BC 260
There are blue and red lines coming out on the copies, how can I resolve this problem?
This is likely due to the drum units being worn out. They were on mine. Once I replaced them the machine was back to perfect photo finish copies and prints. To change out the drum units, first remove the toner cartridges. Next, open the left sliding tray all the way open. This exposes the fuser unit but it doesn't matter because all you have to do is open the side door and slide it out all the way. Next, remove the green screw located at the bottom on each drum unit. This immediately releases the unit and you can pull it straight out. Reinstalling them is the same thing in reverse. I hope this is helpful to those of you who agree that Sharp is not being very cool about allowing the user to work on their own machine, since they don't provide any solutions regarding the drums...Tom
Posted on Nov 20, 2008
  • 163 Answers
Please clean the mirrors and drum unit
Posted on Oct 07, 2007
  • 4 Answers
Try cleaning the little glass strip on the left side of the main glass (that serves documents sent through the feeder), or take off the glass and wipe the dust off the mirrors.
Posted on Mar 17, 2009
    Problem Solver:
  • 18 Answers
Are the lines actually red or blue, or are you not useing your school taught technical terms, of cyan or magenta. Rookies tend to not describe properly as being old school color training we were forbidden to use red as magenta or blue as cyan. IF the lines are in rotation to the drum, you may have bias short or bad drum which gives the affect but basically on the cyan or magenta color, if its red or blue the problem may be further in process. Hard to answer the question wyh such little description.
Posted on Dec 08, 2007
    Problem Solver:
  • 6 Answers
I think this model has led's above the drum unit which write the image onto the drum if you remove the toner/dev and drum unit you can clean them with clean soft cloth
if lines are across page the toner cartridge may need replacing or if machine is old the connector at the back of the toner unit that turns it can be worn and slipping replace them
also clean optics and glass as well
drums may also be worn if you can see metal near to the edges replace drums
Posted on Dec 04, 2007
  • 62 Answers
Also you can clean the the drums with alcohol and soft towel rub softly.
Posted on Oct 18, 2007
Replace the toners send old ones back to dealers for credit sharp knows the have a problem.
Posted on Oct 09, 2007
SOURCE:
I have a sharp ar-bc 260 have perfect black lines on copies only copy mode print mode is fine
Clean all your glass including the thin strip on the left side that handles scanning for the doc feeder. Run copies both off the glass and the doc feeder. If the line is still there then take off the glass, dust the inside scan cavity and dust your 3 mirrors with a new, lint free rag. Make sure your glass is completely clean before you put it back on.
Jan 17, 2011 | Sharp AR-BC320 All-In-One Led Printer
My action replay says it hasnt more space but it hasnt any code in. I dont know what to do.
does ur AR come up with crazy red and blue line when u try 2 add a new code??
Jun 27, 2010 | Datel Action Replay for Nintendo DS
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Lines!
well firstly do the red and blue lines come up always? if so then yes your ds is broken but if not 'no your ds is not broken it is just the game so i suggest you go and get another copy .
Jan 17, 2009 | Nintendo DS Lite Console
ACTION REPLAY DS PROBLEMS
The AR should come pre-loaded with codes for most games. If you followed the directions carefully and there are no codes for your game I suggest following the AR update instructions in the booklet to reset and download the most up to date codelists for your games.
Dec 12, 2008 | Datel Action Replay for Nintendo DS
I CAN SOLVE IT xD no its not broken
heres what u do :D You hold A+B+START+SEL With action replay in then you turn it on while holding Those buttons then when Action replay main screen comes up Release the buttons and then type ID in then it should work
Nov 27, 2008 | Nintendo DS Console
How do i clear error code on AR BC-260 H5-01
I don't have that error code specifically but any error code that starts with an H has to do with the fuser section of the machine. It could be the thermistor, rollers, or the heat lamps.
It should be looked at by a Sharp technician to determine the correct problem.
Oct 01, 2008 | Sharp AR-M237 Copier
Manual for Sharp AR-BC 320 All in one copier
http://www.sharpusa.com/files/cop_man_ARBC320.pdf
Aug 05, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR BC320 not printing correct colors
sounds a lot like the print heads are clogged. Can you print a test page, and how does that come out?
Feb 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC260 Color Copier Logo
280 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
