Copiers
Problem for Copiers
Generic problem for all Copiers
Minolta CSPRO EP2030
By alchs on Oct 05, 2007
When you turn on the machine the panel lights up with error code C05 and a picture of a wrench. Then the machine shuts itself off. any help would be appreciated.
Thanks,
al
Same Problem
Jan 17, 2008
-   I had the same problem and finally found the round push button switch in the back up above..... It took me a while to find it but appreciate all the help you provided-will check back with you if I have another problem.... It does make a noise but I can live with it and it probably needs cleaned because it leave a line down it if anyone knows how please let me know.... Thanking you in advance
-   Guest
Best Solution
posted on Oct 07, 2007
Very Helpful)
DANIYAL
Rank: Wiz
Rating: 78%, 265 votes
respected sir i just wnt to say that open the rear upper cover ,there will be a small micro switch ,while ON the machine press that micro switch your machine will be ready
Was this helpful?
Yes
No
Solution #2
posted on Oct 06, 2007
Very Helpful)
zeron50
Rank: Guide
Rating: 83%, 7 votes
You Can make reset for this code by:
1. Open the front door of the machine & lift the upper half
2. Turn the machine on
3. Locate the srvice switch on the main board( backside of the machine you can reach even without opening the back cover)
4. If this code is coming from time to time just change the upper heater roller
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Not Rated)
CopierOne
Rank: Wiz
Rating: 91%, 49 votes
Hi-
The C-05 is a fuser code indicating that the machine is not warming up. The diagnstics detected that the temperature in the fuser is not increasing and it shuts down This could be caused by a blown thermal fuse (the most common and cheapest to fix) or a bad heat lamp or thermistor (not so cheap or easy to fix)
The fuser is the last thing that the copy passes through before it exits the machine and is not too hard to get into. The fuse is located just a few millimeters away from the heat roller (the teflon coated aluminum roller that is on the top part of the fuser) The fuse is usually available at Radio Shack and make sure that you buy the correct value, usually stamped on the fuse itself.
Hope that this helps. Let me know.
Aloha,
Bill Monroe
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I have a Lanier MS 105 voice recorder that needs to be repaired. Can you repair older products such... (More)
Answer
my mp220 will not scan, it will only print and photo copy
Answer
Error message 45-1 is being display on Konica Copier model 3135
Answer
konica 1216
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
