Question about Nintendo NES Console
Snes I can turn on my snes but there is no sound at all and the picture jumps, moves up and down and doesn't stop. What do I need to do?
  • lkahlow Oct 05, 2007
    What would I need to clean it and how would I do that?
I would suggest that you make sure the RCA jacks are hook up properly, and on the right color.If that doesn't fix it, then its an inside problem.It might need some cleaning.
Posted on Oct 05, 2007
Snes doesn't read games
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
Sep 29, 2012 | Nintendo Super NES Console
When I hook up my SNES there is no picture - what do I do?
Well onlhy use the old consoles on CRT tv styles then.
Apr 08, 2012 | Nintendo Super NES Console
Hi I recently purchased a snes, it was working fine but the power cable was a bit dodgy, but when placed in a certain position works fine, it still seems to work and gives power to the console. The problem...
It is possible that you will need new cords. (It sounds like you power cord has a short in the cable somewhere, so it may need replaced too.) A new video cable may fix the problem, but if it doesn't, the SNES may be on its las legs. In that case, you will need to purchase a new SNES or just turn up the brightness on the TV.
May 01, 2011 | Video Game Consoles & Games
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
Super Nintendo picture flashes in & out on my flat screen
Check your cables and connection, they could be worn or cracked, try using on another tv or use a different device in the same plugins to verify if what is wrong
Dec 04, 2009 | Nintendo Super NES Console
Controller port or system and why...
open and clean the controller pad....or buy a new one....sometimes snes joypad goes crazy with dirty inside the buttons contacts, it gives the impression that is a defective console..but in most of the time..the snes joystick need a fix !!! Good Luck!!!
Sep 10, 2009 | Nintendo Super NES Console
Snes -horizontal white lines and buzzing noise
the best bet is to obviosly try another rf cable or try anothe snes unit.
Jul 06, 2009 | Nintendo Super NES Console
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
Vertical lines show up on my SNES picture of any game.
Do you have a third party AC adapter for it? If you aren't using the original one, check its voltage. Mine was a 9V instead of a 10V and while it allowed the machine to run, I got visual distortion effects similar to what you describe. If it isn't a 10V adapter, go to Amazon and get a real one instead of a cheap third party one. I got this one (http://www.amazon.com/gp/product/B00009ZKWC) and it works great!
Mar 16, 2009 | Nintendo Super NES Console
SNES FUZZY PICTURE
check the aerial cable
Oct 26, 2007 | Nintendo NES Console
Nintendo NES Console Logo
91 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
