Question about Pentax Optio E40 Digital Camera
Camera will not connect
My pentax optio e40 will not load on my computer. I get connection failed. Check printer error. Printer is a dell A960. The acdsee photo software in installed.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Aug 25, 2012
SOURCE:
jbreth
  • 69 Answers
SOURCE: Pentax Optio W20 digital camera
I found a step by step manual for this operation. I hope it helps you get to transferring movies. http://www.pentaximaging.com/files/manual/OptioW20_pc_web.pdf
Posted on Sep 04, 2007
SOURCE: My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Posted on Nov 18, 2008
  • 11967 Answers
SOURCE: I am unable to install the software for my pentax
Set your computer to Windows XP mode.
Posted on Jan 24, 2010
SOURCE: camera optio e40 pentax shows the battery life as
this is not malfunction.
According to its manual, just turn it off ,wait for one minute and
turn it on again. It'll reset th camera. You need to reset the date/time.
Posted on Feb 11, 2010
Obertelli
  • 3006 Answers
SOURCE: error lens 113.0.0.0 pentax Optio
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Pentax service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 09, 2010
Why can't I download pictures to computer?
You can do that by two methods.
1. Memory Media
The E40 accepts SD and SDHC memory cards and has approximately 10MB of internal storage.
Insert the memory into your laptop SD card slot.
You may not need a SD Card carrier as the SD type for both Camera and laptop is same.
2. Connectivity
There is a USB/AV connector on the side of the camera as well as a dock connector on the bottom of the camera.
26041754-feum23phdkkiz3bf0e0pm1n0-4-0.png Pentax Optio E40 Review DigitalCameraReview
Jan 06, 2016 | Pentax Optio E40 Digital Camera
I have pentax digital camera how to turn off green mode from pentax optio E40
Press cursor-down, then use the cursor keys to select the desired mode. See the descriptions beginning on page 50 of this manual: http://c758710.r10.cf2.rackcdn.com/files/support/manual/356_1314745005-527808376_manual.pdf
Jul 29, 2013 | Pentax Optio E40 Digital Camera
Where in the Manual for a Pentax E40 Digital Camera can I find how to download to my computer.
The instructions are on the CD Rom that came with your camera.
Alternatively here is a link to the step by step instructions from Pentax
http://www.pentax.jp/english/support/man-pdf/optio-e40_pc.pdf
Jul 30, 2011 | Pentax Optio E40 Digital Camera
When i enter the usb cord into my optio e40 i get the error "connection error check pr inter"
Oct 10, 2010 | Pentax Optio E40 Digital Camera
Looking for Pentax Optio E65 software
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
Sep 14, 2010 | Pentax Optio E40 Digital Camera
Pentax Optio M40 is not recognized by PC
Mar 02, 2009 | Pentax Optio M40 Digital Camera
Connection to PC problem
Dec 27, 2008 | Pentax Optio E40 Digital Camera
Apr 03, 2008 | Pentax Optio E40 Digital Camera
Pentax Optio E40 Digital Camera Logo
75 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
