Question about Pioneer SD-533HD5 53" Rear Projection HDTV
4a fuse blown
When I try to turn the unit on the stby light turns green then back to red. I can replace the fuse and sometimes it will come back on and work until powered off again. Also In the inside rear center board there is a red light that illuminates when the fuse blows. Left RED LED. Im not sure which board is which when looking at the back of the TV. TV looks great when it works. Any help would be great.
    Genius:
  • 1,694 Answers
1)pull chassis.remove power PCB==the one with large heatsink w/convergence IC's on it 2)Observe four regulators also on same heatsink Remove solder from all reg. pins-clean PCB 3)Resolder 4)solder any/all bad connects 5)replace 4 amp fuse 6)reassemble & test
Posted on Oct 05, 2007
TV cannot turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Action-3: Replace the main board!!!
Mar 25, 2017 | Hitachi Televison & Video
I have an Insignia 42" plasma HD tv. It turned off while watching it. when I tryed to turn it back on I could her click on and I got the green light but it went to red and i could hear it click off. I...
Those transformers on the power supply board have shorted.That why,it killing ur fuse.Which one?Must test and find out,if u have the equipment and the skill.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 08, 2010 | Televison & Video
I believe my tv was involved in a power surge. red/green blinks
Hello:
U just may of blown fuses on the power supply of the television if you are sure it was a surge. If u can open the unit check all fuses on the power supply for open coniditions. If the future is a good Ideal to use a surge proctector as this will protect your equipment. Make sure power is off and remove AC power to check fuses. Sometimes just removing AC power for a least 2mins will reset the unit.
Jul 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Hi i have panasonic Veira model TH-42PX70A my tv has stopped working i have no sound and no picture. when turn on the standby button flashes red. If try to turn on from standby mode the green light appears...
Hello this may be a power supply problem, but my professional guess is that your Y-Substain board has failed. Count the number of times the red light flashes, this indicates the reason of failure of the unit. After which check ur user manual for troubleshooting section, your manual may give you a listing of the number of blinks and what they mean. If you want take off the back and check the fuses on the power supply if one is blown then replace the power supply as just replacing the fuse will just blow it again. If no fuse are blown then have a technician replace teh Y_Substain Board.
Nov 05, 2009 | Televison & Video
Playstation 2, red light won't turn green
Sounds like an internal fuse has blown. There are several guides on the net, and a couple forums discussions. Try here:
http://forums.afterdawn.com/thread_view.cfm/375875
google it up - if you're not happy repairing it yourself (which needs just a multimeter and a hand full of small, generic fuses) then you'll need to get it professionally mended. which could cost you more than simply buying a new one.
Apr 06, 2009 | Sony PlayStation 2 Slimline Console
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Pioneer SD P50A5 red light stays on, green lights up but does not stay on
It's internal, located close to many other fuses, the one in question is a 4a 125v fast-blow.
Get a flashlight, (after opening up the bottom cover on the back) and look at ALL the fuses
on the power supply board. Search intently on finding a 4a glass mini-AGC board-mounted fuse.
MAKE SURE the TV is unplugged when you do this!
Oct 07, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Jun 24, 2007 | Sony FWD-50PX2 50 in. Plasma Television
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
93 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
