Your vehicle is equipped with the Passlock theft-deterrent system.
Passlock is a passive theft-deterrent systemT. he system is armed once the keyi s removed from the ignition. Passlock enables fuel if the ignition lock cylinderi s turned with a valid key. If a correct key is not used, fuel is disabled.
During normal operation, the THEFT SYSTEM light will go off after the engine is started. Ln the unlikely event that the engine stalls and the THEFT SYSTEM light flashes, wait until the light stopsf lashing before trying to restart the engine. Remember to release thkee y from the START position as soon as the engine starts. If after several tries the vehicle still does not start, the vehicle may need service. At this time, you may also want to check the fuses. See your Pontiac dealer for service.
If the THEFT SYSTEM light comes on while the engine is running, a problem has been detected and the system may need service. See your dealer for service. In an emergency, call the Pontiac Roadside Assistance Program at 1 -800-ROADSIDE or 1-800-762-3743.
This ans other details can find it in
this link for 1996 Pontiac Sunfire - Owners Manual.
I hope helps (remember to rate and comment this).
try and disconnect the sterio you put in and see if it still drains it then
