Question about CTX Optoma EzPro 585 Multimedia Projector
CTX EzPro610 - No Signal
When the projector comes on after counting down there is No Signal in the right hand corner. I cannot access menu or reset, etc. Nothing happens. This is with a computer, a video, or the projector just by itself. Any suggestions? This projector is used at my school and we can't afford a new one. Thanks!
  • 2,239 Answers
Unfortunately, you may need one. if you cannot even access the menu, you have a main board issue.
Posted on Aug 19, 2009
SOURCE:
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
How to reset filter settings
there is a filter counter option in the settings menu that will give you the option to reset the counter. once in this menu navigate to the "Used Time" option and there wil be a reset button there.
Apr 10, 2013 | Sanyo PLC-XP100L Projector
I follow the set up proceedure to connect the projector to my acer laptop. I then switch on power to the projector and boot the laptop. After the 30 second count-down I et a no signal message which stays...
Not wishing to show Grandmother how to **** eggs, but there are three VGA sockets. One of them is VGA out.
Can you select the inputs on the menu system?
Hope that helps.
Feb 23, 2011 | Sanyo PLC XU30 Multimedia Projector
The bolb come on then shuts down is there a manuel way to reset the lamp.
To reset the lamp timer you must be able to access the on screen menus. If you can't and the projector shuts down before you can do so then the lamp is unlikely to be the problem, howevere this is how you reset the lamp timer.
Turn the projector on, and press MENU
Press the POINT LEFT/RIGHT buttons until you get to SETTING and then press SELECT
Press the POINT DOWN button and a red arrow icon will appear. Move the arrow to the LAMP AGE and then press SELECT
Select YES to reset the lamp timer.
Feb 20, 2011 | Sanyo PLC XP30 Multimedia Projector
Can't access Menu
I have the same problem, any ideas to solve.Thankyou
Feb 22, 2009 | BenQ PB6100 Multimedia Projector
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Dec 04, 2008 | Office Equipment & Supplies
No input on RGB1, etc.
First find someone you know who has a working unit, just to make sure you don't have a problem with your PC output or the cable so you KNOW you have signal at the input.
If no signal then, make sure your input is "configured" correctly in the user menu.
I would have to think your VGA input board on the projector is faulty but let me know what you find.
Jan 15, 2008 | Hitachi (DT00431) Projector Lamp for...
CTX Optoma EzPro 585 Multimedia Projector Logo
268 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
Lampdeng.com
Lampdeng.com
Terry
Terry
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
