Question about Grundig G1000A AM/FM/SW Radio
Radio not working
My Gundig G1000A works fine as a clock. However, when I turn the radio on (any band FM/AM/SHortwave) it works for about 10 seconds then the LCD goes blank and the reception goes to a quiet static or nothing.When I turn off the radio, I got a clear time display.
SOURCE:
SOURCE: Loses sound
It is soppoused to seek when pressing search and scan and scan buttons If you dont like the idea of that for now on only use tuning up and down dial or buttons.
Posted on Jun 25, 2007
  • 43 Answers
SOURCE: Grundig Satellit 800
(650) 361-1611 - 3520 Haven Ave, Redwood City, CA
This is the closest location I could find, hope it helps.
Posted on Feb 04, 2008
SOURCE: users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Posted on Feb 28, 2008
IB4G2008
  • 3587 Answers
SOURCE: Can't get AM and SW, FM is fine. Nothing but Humming on AM/FM
humming? as in 60 cycle hum or no signal hum?
Posted on Mar 16, 2008
  • 58 Answers
SOURCE: I have a Grundig Satellit 500 "Radio Boy"
If you sent it in 3 times, then I would suggest getting a new one if you know for sure that other's work in that area. If other's don't work, then then you have some type of interception between the radio waves and your radio. There is nothing I can do about that, and probably nothing you can do.
Otherwise, you should get a new radio.
Manual for grundig 750 radio
Here is a link to the manual for your radio.
http://www.etoncorp.com/sites/default/files/GS750_Manual.pdf
Dec 11, 2014 | Grundig Eton Satellite 750...
How to turn on radio
Just press the larger On / Off button, lower left side of clock, select AM / FM band (make sure you install either the am band wire antenatal and the FM antenna (comes with clock) use the rocker arm switches to search out stations and adjust volume by turning knob on the right side of radio, that's it... (0:
Mar 31, 2013 | RCA RP3721 Clock Radio
Cannot select USB or SSB.Displays LSB or LISB? Very poor reception
On the Satellit 750 you have a button marked SSB. If you have selected a shortwave band then you can press the SSB button. Pressing the button repeatedly will toggle between LSB and USB.
You will need to know the exact frequency and the broadcast time, and the side band. Turn the radio on. Select a frequency which you know carries SSB signal and wait. Those that broadcast on SSB are not radio stations, maybe ham radio operators.
You can also select a short wave band, press the SSB button once or twice to select the side band and launch the automatic tuning system. It will scan the meter band and stop for a few second when it receives a strong enough signal. If you are able to perceive a clear signal on LSB or USB then you found a broadcaster. Some radios just have SSB and you cannot choose the side.
Personally, when I buy a radio I always insist on SSB but I have never been lucky tuning in an SSB signal. I keep trying once in while.
Jun 23, 2011 | Grundig Satellit 800 AM/FM/SW Radio
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
I just purchased the G6 Aviator. The FM band works well, but none of the AM or shortwave stations get reception. I have tried the antenna up and down, indoors and outdoors with no success.
It sounds like the whole am band is not working which includes the shortwave bands, there is no remedy to correct this and is clearly a manufacture defect. The best solution is return the radio because there is nothing more that can be done in it's present condition.
Mar 03, 2011 | Grundig G6 Aviator (Buzz Aldrin Edition)...
Radio phillips aj100 stuck on am band cant get it to switch over to fm frequency.
Press RESET under the radio a few seconds. Adjust clock, alarm and radio again. AM gone, FM back on the air...
Jul 26, 2010 | Philips AJ100 Clock Radio
No am on am band
Usually the "front end" of the radio has a bad FET transistor. This is caused by a static zap at the antenna. Early models suffered from this and the cure is to replace the FET and add protection diodes. If you need help with this email me at.... [email protected]
Rod
Nov 08, 2009 | Sony ICF-2010 AM/FM/SW Radio
Kaito 1103 Shortwave Radio
I dont have this radio but I remember reading that you push the volume button then turn the tuning knob to change the volume.
Sep 23, 2008 | Kaito KA1103 SW/FM/AM Radio
Shortwave programmes
Before you call a doctor or an exorcist, verify that you're using your shortwave receiver under normal condition. There are several factors which affects reception of whortwave programs and signals.
1. Check for the time and frequencies. Depending on your country and location, all Shortwave time zones are based on World Time in UTC or GMT ("Universal Time Coordinates" or Greenwich Mean Time") In my country (Philippines, Asia) for example, we are 8 hours advanced from World Time. You can check your time zones and regions using a world map.
2. Check for propagation and band conditions/ openings. During daytime higher frequencies such as 9 -21 Mhz are active, while nightime frequencies are the lower bands such as 3 - 9 Mhz. Daytime and nigthime divider frequency is about 10 Mhz, that means you might receive signals under most conditions during daytime and night time. Check some technical books on amateur radio operations or magazines for radio reception. It might be worthwile to study books or materials on receiving international broadcasts stations before you can receive good or adequate shortwave signals. This might become your hobby too, "DXing" or receiving distant stations from across the world. Try it, but it might be an addicting hobby once you're drawn to it!
3. Check if any shortwave station broadcast in any specific time of day at any frequency. Shortwave broadcasts are scheduled based on band openings mentioned above. If for example I'm a Shortwave broadcaster from Asia, and would like to broadcast my signal through the Americas, I would use band openings with respect with time zones. If it is night time in the Philippines, and daytime in the Canada, I would use the higher frequencies to propagate my signal. So I would specify the time for example "8:00 pm Philippine local time, 12 hours UTC, and 7 am in Canada"--- Asia: 8 hours advanced to UTC, Canada--- 5 hours behind to UTC). So shortwave broadcast schedules varies. Broadcast schedules are available on the net, just search for the Shortwave station you want to hear such as Radio, Japan, Radio Australia, BBC, DW (Deutche Welle) Radio in Germany, China Radio International... There's too many shortwave stations waiting to be discovered out there! Check some books and magazines too such as Popular Communications, Monitoring Times, Passport to World Band Radios, World Radio and TV Handbook, etc. You may want to check if any station would be broadcasting in your dialects as most of these mainstream and regular broadcasters are multilingual.
2. Check your location. If you are using your radio indoors, shortwave signals might not entering your homes or offices due concrete walls and metal railings or fence. There are many factors which blocks radio waves especially in the HF or lowetr bands. Try receiving AM (Mediumwave) first. If it cannot receive any AM station, then you would not receive any Shortwave signal at all, even if you extend fully the telescopic whip. If you cannot receive AM or Shortwave signal indoors, try using your receiver outdoors.
2. Check for local interference. Your receiver might be receiving interference from noise generating gadgets such as PC monitors, TV sets, faulty wall adapters or switching power supplies, motor operated appliances such as washing machines or vacuum cleaners, flourescent lamps, etc. Try turning off or unplugging each of these mentioned gadgets to see if they are the cause. Faulty house wiring or powerline noise might also cause some interference noise which could drown shortwave signals, verify this with your local electrical technicians.
3. Check your radio's settings. Depending on the radio that you use, there might be settings such as attenuator or RF gain, be sure that attenuator are set to zero or turned to off, and RF gain to high. Attenuator must be turned to minimum or OFF position, unless you are receiving too much signas from nearby radio stations. Setting attenuator to mid or high position will attenuate most weak signal, and only those strong local stations will pass through. Setting too much attenuation will prevent you from receiving any station at all. Same with RF Gain, always set it to highest gain setting unless you are receiving too much signals which might overloads your shortwave radio.
4. If these troubleshooting efforts above doesn't works and you still cannot receive any station, then your radio's front end parts might had burn out due to signal overloads. Burn parts might include one or several transistors or diodes. Let your local service technicians check your radio and solve the problem for you. If your radio is still under warranty, send it back to the store or dealer, and let a qualified technician do the repair.
MANNY DE GUZMAN JR.
SoundMagik Home Studio
Site Creator, Teen Models 2007
Visit my website at http://mannydeguzmanartist.wetpaint.com/
My YouTube Channel, http://www.youtube.com/user/mannydeguzmanjartist
My imeem social media channel, http://mannydeguzmanartist.imeem.com/
My Talents and Modeling site at http://teenmodels2007.wetpaint.com/
I've also signed up an account at Total Popstar, uploading some promotional videos. You can watch and rate my videos (you can find my videos on the right side of the screen), just click the link here: http://www.totalpopstar.com/?profile/index/&1740
Thank you very much. I hope I'll really be of help here at FIXYA.COM!!!
Jan 26, 2008 | Sony ICF-SW30 Radio
Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
am fm receiption not the same most likely antenna make sure the antenna wire fit tightly in radio cheers
Jan 08, 2008 | Sony XPLOD CDX-GT200 CD Player
Grundig G1000A AM/FM/SW Radio Logo
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Sheldon Dedek
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
